Fuel pump not coming on, not the relay, fuse, pump, or computers...
iPod Tamer
Okay my fuel pump is not coming on in my 88' 951 project car. I have known good computers in the car, good relays, and a good pump. All have been swapped out with good spares to double check. The pump is simply not coming on, and the fuse is good. Anyone have any ideas?
Could be the speed or reference sensor, can’t remember which one.
I don’t remember exactly, the fuel pump will not turn on until the engine turns 30 rpms.
I believe you can use a jumper on the relay contacts to run the fuel pump.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Check for voltage at the fuse. If you have it there (with the key on) then the problem is between the fuse box and the pump (or the pump itself). If no power at the fuse then it is a DME or realy problem.
iPod Tamer
When I first got the car I discovered the DME was not working so I switched it with my good one and have since gotten a replacement but neither make the car start. The previous owner said he was just driving the car and it died on him and could never get it started, which is where I am picking up from in diagnosing this no start issue. But I am having trouble trying to connect why the DME was dead along with what appears to be a no pump issue.
iPod Tamer
I will try another jumper today when I go outside to work on it. The only question I have about the jumper in place is that I have put two different GOOD relays in the socket, so shouldn't those make it come on if the original relay has an issue?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
BTW – an ‘undocumented feature’ of the 944 electrical system is that the power for the O2 sensor is on the same fuse as the fuel pump. If the O2 sensor wires get melted it will pop the fuel pump fuse.
I was doing a quick diagnostic on a car the other day (along with Evil944t) and we wired the fuel pump directly to the rear defroster. That got the fuel pump running.
iPod Tamer
So I worked on the car some more today and still the fuel pump will not come on. I tried putting a jumper in the relay again and the pump will not come on that way. I also tested for voltage at the fuse and at the pump with the key on and I am not getting anything. I pulled the fuse box up to look for bad wires, looked around under the dash, checked the wiring near the tank and everything looks fine. Does anyone have any ideas of what I should look for or test next?
iPod Tamer
Everything seems to work fine. If I put a jumper in the relay, the water pump for the turbo will start running but not the fuel pump. If I spray some starter fluid into the intake the car will fire right up and run for about 5-10 seconds.
There is a 2 pin wire connector above the fuel filter that connects the small fuel pump harness to the main wiring harness. I' ve found it is a good place to look for an open circuit or a voltage drop
iPod Tamer
I also tried switching out that harness with a low mileage one that I had, and still nothing. I don't seem to be getting any voltage through any of the wiring to the pump.
iPod Tamer
