How many people have removed the ceramic coating in the exhaust ports?
Has anyone sucessfully ported and polished the exhaust ports on a 951 head? I already did the intakes (slightly larger with a a mirror finish), and the only thing that is stopping me from doing the exhaust side is the stock ceramic coating. Anyone here run into problems with removing it?
You can have exaust ports ceramic coated after porting job.
I didn't port (not needed on 16v S head ) but had exaust ports coated to reduce heat transfer to fragile 16v head.
im pretty sure that those are cast into the ports- so when they crumble or come out your left with a large port- bigger than you may want. Most people porting heads for a turbo get an n/a head, port it and have the hotside ceramic coated afterwards.
Defending the Border
Rest In Peace
Rest In Peace
Wasn't a textured finish in intake ports designed to keep fuel suspended?
had the 951 head ported not sure if my mate used Diamond tooling to do it . but the flaking off is a massive fear the turbo is spinning so fast i think a single pubic hair could destroy it
Personally, I think the "textured" or "satin" finish= better fuel atomization argument is nothing more than an excuse not to spend an extra hour polishing the ports. It takes 15-30 minutes to hog out a port and leave that "satin finish" lazy people love... finishing the port to look almost like chrome takes a lot more work. So by pushing that therory around, they dont have to work as long.
Thanks guys. Ceramic coating the exhaust ports is a bit expensive... I am glad to hear that people were running without the ceramic coating. So I guess all that would have to be done to swap the NA head onto a 951 would be to swap the exhaust valves over right?
Speaking of NA heads, has anyone swapped a NA cam into a 951?
As I understand it, the heads are cast around the ceramic ports. There is a great picture in a book called Forced Induction Performance Tuning (probably a porsche pic), which shows the ceramic port without the casting around it. It looks to be 3 or 4mm's thick. (That book also has some great misinformation about the 951 -- including a paragraph on how the DME monitors knock by cylinder and can pull timing to only the knocking cylinder.)
951 uses the same cam as early N/A cam was. The only difference is height of exhaust side which is 11mm with 951 cam and 12mm with 1985 and newer n/a cams. Otherwise they are identical. 951 cam should have stamping 05R. Late n/a cam has 09R.
So the lobes are 1 mm higher, the effect is what? The valve opens a bit more allowing a better expulsion of the exhaust gas? In the grand scheme of things how much does this help?
IPSC
IPSC
