Spoolup 500-600 too slow. *updated with dyno chart
The Impaler
I knew the spoolup was less than perfect on this car, but I did some side by side comparisons and did some searching about the spoolup others are getting with the vitesse stage II, and i think its pretty bad. Im getting 15psi by 3800-3900 rpm's. The response is lacking. It still pulls very hard, just spools slowly.
Ideas:
Gigantic exhaust leak?
Collapsed down pipe?
Something wrong with the turbo?
This is the old version vitesse turbo.
Ideas:
The Impaler
I have the Tial 38mm. I dont THINK Im leaking boost from the IC couplers, because the car has been spooling slow since before I bought it, and it had stock pipes then.
The Impaler
I havent done one, but that doesnt seem like it would be the cause. The engine was rebuilt a few 1000 miles ago, and while the rings weren't replaced, im pretty sure the PO checked the compression when he bought this motor, and it was good.
The Impaler
Im definately thinking that it could be a collapsing x-over or down pipe, it seems to have gotten slightly worse since I bought the car. Im running stock exhaust with no cat. I cant test EGT's.... yet.
Start with the simple things before proceeding the the PITA to check components.
Which Boost Controller are you using?
Is the Boost control system working properlyn (boost controller, WG, lines,..)?
Is the BOV holding pressure?
Any vacuum leaks?
What is the fuel pressure? (It must be 3bar static)
What position is the FQS?
Is the car running rich?
Is the air filter clogged?
If none of the above! Test backpressure in the X-over pipe, this will tell you if there is a restriction.
On your turbo, 4th gear, you should be hitting 1bar boost around 3200rpm.
Any vacuum leaks?
The Impaler
AFR is about 13.5 - 14.0 on full boost through all rpms.
Air filter is a bit clogged.
Fuel presure is at 3.0 bar.
I have tried two different BOV's and that didnt seem to change anything.
vaccum seems to be fine at idle, -15 or -16 usually.
I havent looked to see what position the FQS is in.
How can I test pressure in the x-over pipe? If been thinking about doing this anyway, along with an EGT monitor.
Ideas:
Ideas:
Its been an exhaust leak 80% of the time in my experience.
The Impaler
I used my excellent cross-eyed surveilence skills to guage the spoolup.
Im not sure exactly when im getting 15psi, but im sure its close to 4k, so I know thats not right. I am dying to go hunting for exhaust leaks, but i cant find my stupid jackstands.
Herr Unmöglich
Whoa, did you know 500-600 was the secret code used to indicate to troops that they should kill Che Guevara after his capture 40 years ago today?
http://news.bbc.co.uk/2/hi/americas/7027619.stm
The Impaler
Wo i didn't know that was too lean. I just went out ofr a quick run to verify that, and it sitting right at 14.7 on idle, and sticks at about 13.8 under full load. What should the AFR under full load be?
