Source For Bosch MAF Connector
I need the male electrical connector that matches the connector on the original Bosch MAF. Does someone know if they are available or do I have to sacrifice a MAF and pull the connector off.
Thank You,
Richard
Thank You,
Richard
http://www.eagleday.com/ampconnectors.html
Male? sorry I don't think they're on the site. Used AFMs go pretty cheap on ebay, I might even have one in the cabinet in the garage.
Assume you are referring to the factory air flow meter connectors. I looked for the male side for a bit and ended up buying a broken AFM for $10 and pulling the connector off. Used it to make an adapter box to hook up a true MAF without cutting the factory harness.
I searched today and found the same parts offered by Eagle Day, specifically the 6-Pole Female AMP Junior Power Timer Connector. The male was nowhere to be found. Yes, I am trying to avoid cutting the harness. I have had my eye out for a Bosch MAF to remove the receptical. There was a Bosch MAF for a Volvo that looked like it used the same 6 pin connector. I would rather part out a non-functioning MAF then trashing a working unit.
Performance Developments has them. Just what you need. 949 646 7461. I had some on a project they did for me. They made them just the same as the 3.4 and 6 Pin connectors. Bosch nver made the 5 pin.
if you need the harness side female plug- i have one from a 924s same as n/a and turbo. I cut it off about six inches from the plug awhile back for someone then they backed out.
PICTURES????
Tom, I was wondering what your adapter box looked like. Thanks for the pic! Received the pics of the P.D. connector. Perfect! Called them up today and they are going to set me up. BTW, nothing perks up the engine bay like a new coolant tank.
