Bigger Injectors Advice
#31
#32
running 55lb siemens from Marren injectors - no resistors- 3bar and max chips- ran this setup w/ my stock turbo and now w/ the 27/8 and numbers are great that ive logged both ways.
#33
-low impedence
-high impedence
one of them requires resistors, the other is a stock plug-and-play solution.
#34
With the Python 83# injectors I had a perfectly smooth idle in all temperatures, from below freezing to 100'+ F. I have recently switched to Siemens 86# injectors and the car still idles great but has a very slight up and down idle where it goes between 800 and 900 rpm, and the same even with the A/C on high. This, I am certain is only because I have yet to adjust my LINK for the difference with the new injectors, the idle difference is because it's changing "cells". Once I adjust it so it can interpolate between the two cells better, it won't be switching back and forth...and thus back to a perfect idle. I also use a MAX chip with the LINK.
#35
Which version of Link are you using Stephen?
#36
It's an older Link AFM, bought it cheap to use for testing but like many things I ended up liking it's reliability and consistancy once I got it tuned. My idle moves between 850 and 900 rpm with the new injectors, not 800 - 900 as I had listed before.
#37
I pulled of my intake this weekend and 1 of my injectors broke and the caps on 2/4 broke off so I need injectors sooner than I expected.
I want to upgrade my injectors as I will be buying 951Max chips, currently have either Lindseys or some other brand according to PO.
I have a 3bar Fuel reg, MBC, 3" exhaust without a cat, Venturi delete, unknown wastegate, and stock k26/6 turbo.
I know Vitesse sells a set for $325 of 55lb injectors, but I want to spend around $200-250 for a set of 4 somewhere in the 40-55# range.
Where are all the good deals?? I want something plug n play, I dont want to mess with resistors.
http://cgi.ebay.com/ebaymotors/Bosch...mZ220256836396
Really cheap at US $27.50 a piece!!
Gerald
#40
i will soon have a local injector shop perform a side-by-side comparison test between the stock bosch injectors vs siemens 55lb vs delphi vs. rc 1000cc.
i'll be testing for:
1) flow characteristics (i'll take photos of the spray pattern at various fuel pressure/duty cycle)
2) fuel pressure limit (we'll turn up the fuel pressure to 60psi+ and see if the injector still functions correctly)
3) actual flow rate (vs. advertised flow rate)
if anyone has any other comparison suggestions, please post up.
here's a photo of the delphis;
![](http://gallery.silentmedia.com/main.php?g2_view=core.DownloadItem&g2_itemId=153811&g2_serialNumber=1)
#42
If you have not bought injectors yet, check these out!
Gerald
Gerald
#43
![](http://gallery.silentmedia.com/main.php?g2_view=core.DownloadItem&g2_itemId=153800&g2_serialNumber=2)
I think it would be very interesting to also test the minimum amount of fuel metered per pulse. My understanding is that the design of the Delphi's is such that this amount would be much lower than for the others. This in turn should mean you could run much bigger Delphi injectors without idle problems which could be interesting for people considering running a dual fuel setup - E85/Pump Gas.
#44
hey that's a great suggestion. i'll add that;
4) minimum amount of fuel metered per pulse (for idle characteristics)
