My car is leaking atf. And the brakes are sqweeking...???
Okay so i pull my car out to take it for a short ride before dinner, and i come back to atf or power steering fluid all over the driveway. So i get out and check the tank and its almost empty. I also noticed that the brakes were sqweeking more than normal does the atf have anything to do with the brakes....??
It may not be the rack, there are rubber hoses from the tabk that go to the pump and to the rack, there is also rubber connections on the p/s cooler line.
Those all have hose clamps (and a couple of crimps) and could be leaking from there.....check that out first.
