XP: Is my KLR bad? -- Help fix my low boost issue :)
I don't think my DME is culprit tho...I must've stared at that sucker for half an hour, searching w/ a magnifying glass for any crack/imperfection in the solder joints and i found nothing. The solder's a bit dull, but that's it. All of the resistors and whatnot appeared (visually) to be intact as well.
Originally Posted by ausgeflippt951
Hmmm...my tach bounces, I get oil pressure if I crank for ~12 seconds, and I am getting spark to cylinders 1 and 4. I did not check 2 and 3 because I didn't have enough time. I guess I could check 2 and 3 tomorrow...
Might it still be the KLR?
FWIW, I checked the wiring harness for the injectors and w/ the ignition on I read 12V for the right terminal to ground and 10V for the left to ground.
Injector resistance is 5 ohms for each injector.
If you have spark, the klr seems very unlikely. A lot of stuff in DME and KLR both have to be working to fire the plugs, it's the same circuit that fires all 4 plugs. It still could be a bad DME but not very likely.
Have you confirmed you get fuel? Pull a plug after cranking, how does it look, fresh gas? Possibly weak coil, enough to see the spark but not enough to start?
If you suspect the KLR why not just bridge it out and see if the car starts - it is a diagnostic mode, so you shouldn't really drive it like that and it won't make much boost... but at least you'll know if a bad KLR is stopping your car starting.
Page 38-42 PWM
The engine can be operated without the K/CP control unit in an emergency or for trouble shooting purposes.
In order to do this, the ignition signal must be bridged at the K/CP control unit plug terminals 9 and 16 with an auxiliary wire.
The engine will then run with reduced power.
Page 38-42 PWM
I actually got the car running two days ago for no apparent reason. I had been running many diagnostics and as a result, I cleaned everything, but the car started right up. I drove it for two days w/ no problems.
And then it wouldn't start last night.
Long story short, I was able to get it going using some starting fluid. The car will hiccup when the oil isn't up to operating temp; after about 20-25 min of driving, the hiccupping seems to go away.
Bad dampener/regulator, perhaps?
Thanks guys!
And FWIW, I am still getting only 1.25 bar of boost. Tomorrow I plan on clamping the WG-CV line to check for max boost; I'll let y'all know what the outcome is.
Thanks guys!
^Bump^
Could a bad dampener/regulator be the reason for the hiccupping? I can find no correlation between hiccups and bumps in the road, speed, engine RPM, throttle position, constant vs. increasing throttle, etc. It seems completely independent of everything on the goddamn car.
Bad speed sensor, perhaps? When the car hiccups, the tach immediately goes to 0 RPM, which could be indicative of a partially faulty speed/ref sensor...
And in regards to boost, I was noticing that I didn't even check the KLR harness underneath the intake manifold when I was replacing the vac lines. Unfortunately, I have no real idea how a totally stock 951 is supposed to drive, i.e. I don't know if the timing is permanently retarded (causing the fail-safe mode that the KLR reverts to).
Could be a lot of things still. Did you ever get to clamp the WG line? I wonder if your AFM is wigging out. These type of problems are so hard to diagnose. Type an get her started so that she will idle and try the blink code test again so we can cut out some of the causes. Also tell us how the car acts when it hiccups (shakes? Oil pressure?)
Spend some time going through the shop manual at clarks-garage.com if you already haven't.
Thank for the advice. Unfortunately today I'd been a bit more busy than I had anticipated. Tomorrow I plan on:
blink testing
installing my LBE to see if I can get a boost increase if the previous two check out OK
I've been searching nonstop on Clarks and haven't quite found what I've been looking for. I ran diagnostics on the AFM (even going so far as to take off the cover and testing it there) and everything checked out perfectly.
When the car hiccups, it recovers just as suddenly as it came in the first place. The whole thing is only a fraction of a second. The tach will go to null, RPM will drop slightly (due to engine shutting off for a blink of an eye). As far as I can see, oil pressure will not drop instantly like the tach (indicative of no signal). Unfortunately i can't be 100% sure due to it always catching me off-guard. i have to drive the damn thing in the morning so I'll be on the lookout.
Tomorrow I will also take the vac lines off of the dampener/reg to see if fuel comes out. This would be indicative of a bad FPR right?
Thanks for all the help with this. I truly appreciate it
blink testing
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
When you clamped the WG line, boost should have peaked well beyond the 2bar that the dash gauge indicates.
Exhaust obstruction? Intake obstruction? Turbo malfunction?
Yes checked the AFM. In fact, every piece of electronics I've done diagnostics on has checked out just fine.
After classes today I'll do the aforementioned checks.
Yup absolutely. However, last time I did the clamp, the car refused to go any higher than 1.85 bar or so. Theoretically it should easily hit 2 bar, correct? I'll post an update tonight.
Also, I'm beginning to seriously think it's my FPR or damper. Today as I was driving to the uni the car did its occasional hiccupping, but on one occasion the car backfired like crazy -- about four of them in very quick succession, followed by a huge plume of black smoke. I was just cruising at 40mph at the time. After the backfire, the car ran quite normal, as if nothing had ever happened. Until the next time it hiccupped, that is.
How can I differentiate between a bad damper vs a bad FPR?
