Gapless Rings
Old 10-29-2007, 07:47 PM
tommo951
tommo951's Avatar
Originally Posted by nick_968
What bore material are you using Tom? I never heard of anyone using them on alusil....or do you have the perfect bore nicosil sleeves?
Hi Nick,
Yes using Perfect Bore Nikasil plated bores.
Must get to see your 968 some time, it must be running awesome now!
Old 10-29-2007, 07:52 PM
tommo951
tommo951's Avatar
Originally Posted by 2bridges
Hey tommo951 - suspect you know this, but just a heads up.
Zero gap rings I have used (not 944) are ususally made "long" and have to be fitted. installing without propper fitting will deform the ring in the bore and very likely damage the cylinder and piston.
Thanks for the heads up 2bridges. I am always very diligent about sizing rings to bores. It is so easy to rush into things and then you have plenty of time to repent at your leisure!!
I will be interested to see what bore wear is as there should be less tension on the rings as Chris White pointed out.
Old 10-29-2007, 08:00 PM
gt37vgt
gt37vgt's Avatar
I herd from the Piston guru that pressure is trapped between first and second ring so only use gapless top ring . And some one else says file backs
Old 10-29-2007, 08:13 PM
nick_968
nick_968's Avatar
Hey Tom
Anytime u like, not quite finished, just need to fit 044 pump before going to dyno for mapping. Other little jobs just keep popping up, but should be done soon!
Old 10-30-2007, 09:05 AM
Alpine951
Alpine951's Avatar
I have seen posts on here that EBS recommends only using the Total Seal on the 2nd ring.
Old 10-30-2007, 10:06 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Total seal has developed a gapless top ring that will work with turbos - it was not availalbe until about 6 months ago. Before that even total seal did not recommend a gapless top ring for turbo use.
Quick Reply: Gapless Rings
