Orange vacume line at firewall...
Uhoh. I do not see a y connector anywhere? Where does the orange line lead to? Can I just T off another connection and plug it in (I have the lindsey vacume kit) Thanks guyssss
Mine joins another vacuum line(black/through the firewall above the battery)via the "y" and the remaining hose runs to a blue/black valve(check valve?) up high(by the oil fill cap).
The L vacuum kit has my attention, but I don't know much about it yet.
It's July 4, it's raining, my 951 isn't running...GRRR!
Originally Posted by oldjammer
so....do silicone vacuum lines collapse with the engine heat??
that organge line is for the heat valve that has to beconnect or you will run rich. that happen to me it popped off the y-connector
Oh boy - what??
That has nothing to do with fuel.
They are vac supply to heater control inside the car to then open/close the heater valve OUTSIDE the car above the clutch.
If you ran rich disconnected, it must be downstream of the fuel regulator on your car.
It looks like your 951 has been the past victim of a knucklehead, Carlos.
You better bring that up here.
Originally Posted by special tool
Oh boy - what??
