Best Ring Compressors
Tom,
I found the units from Summit to be fool-proof. And I think I'm a pretty effective fool.
Summit Compressor
Just get the correct size for your application.
-Jon
Summit Compressor
-Jon
I like this one from Snap On, you can even see through some of the openings to see how everything is seated. If you use this one, better to save the head stud installation till after piston install.
Bret -- I actually have a very similar version, but the edges overlap and look like they'd overlap the o-ring in the cylinder tops.
Jon -- sadly they don't have one in the right size range for me... They have a fixed size version that is about .0015 inches (1.5 thousands) too big. Close enough?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by Jon Moeller
Tom,
Summit Compressor
-Jon
Summit Compressor
-Jon
Originally Posted by Chris White
These are the ones to use, I have a couple of them to cover the whole 100mm to 108mm range.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by Tom M'Guinn
They don't seem to sell an adjustable version to fit a 104.5mm (4.114 inch) bore. Closest they sell is a fixed diameter version at 4.115 inches, which will probably work (in light of the chamfer mentioned above).
My adjustable one seems to work fine, I will check the sizing on it.
Well, as it turns out, I assembled a small collection of compressors...
No. 1 is a pain, literally. It has razor sharp edges and was difficult to expand and contract without cutting my hands...
No. 2 is the best (made by ARP, sold by Summit). It has all the benefits No. 3, but also can be tightened and loosened, which is critical when the piston gets stuck in the sleeve. By far the easiest to use for me...
No. 3 is great (sold by Summit), but each sleeve works only for exactly one size of piston. Also, with a sleeve the same size as the bore, the pistons liked to get hung up in the sleeve, which is why I preferred No 2 above. With number 2, you can loosen the sleeve a bit, straighten the piston, and keep going. With No. 3, you have to work to get the piston unstuck and then start over.
No. 4 is good for most motors, but with an o-ringed block, the sleeve sits on top of the o-rings and can nick them.
just thought this might help someone down the road...
I'll second that #1 is unpleasant. My old roommate and I were building an engine for his nissan 240 and we were trying to get the piston in and my roommate cut the **** out of his finger with that damn compressor!
