Rims that will fit a 86 951? anyone?
So right now i've got some 968 cup rims on my 86 951. Yes, i do have very THICK spacers. I experience a bit of understeer with my 205/50r16 or whatever they are and no, i dont think its due to cheap tires. I've got a staggered setup with 205 16" in the front and 225 16" in the rear. on occasion i do experiance understeer as well as oversteer. I want more tread on the ground and keep the handling tight and not just add wider tires to the rims i already have.
So what are my options? What can i get with what i've already got? Whats been done?!?
well as far as what bolts right on there are a few options
stock phone dials -early offset of course
Fuchs- came stock on some early turbos 16"
Cup1 and 2 replicas - heavy 17" but bolt right on and look nice
Several other aftermarket wheels that have correct offset but the $ gets higher and higher as you go. I have some 2001-04 996tt widebody wheels on my car 18" and with a spacer up front and a 15mm slip on spacer in the rear they work fine. I also have 8" early phone dials i run for the track that fit with no problem. Whatever you get youll need 23mm offset front and between 15 and 23mm in the rear without spacers.
UAE Rennlist Ambassador
Originally Posted by 2bridges
16X8" fuchers on front (originally 86 951 rear)
16X9" 930 fuchs on rear (rear or 930)
no spacers - nice fit
polish for good measure
Rare, super light and super expensive....
Too bad i cannot find 245/45/16" tires here for them im spinning 1st and 2nd......
for late offset conversion you would need
spindles
hubs front and rear
rotors front and rear
lower control arms front
late offset wheels
alignment
late offset inner tie rod ends
spindles
hubs front and rear
late offset wheels
alignment
Originally Posted by hosrom_951
Man, those old school Fuchs are such a beauty when polished!
can't get 245/45 ??? thats tough. Limited options here in a true performance tire that is not pure track. Most are cheapie speed rated or pure race tire. Hankook rs2 is only reasonably treaded street/track tire I found that could be used in rain.
Just send those on over here and I'll give them a good happy home
