Are drivers and pass seats revesable?
I have a worn bolster on the drivers side, the passenger is fine, I was going to drop off at upholsty shop w/ a few other pieces. Then put the passenger seat in drivers side until the drivers seat is ready.
Is this possible?
Steve
Is this possible?
Steve
Sort of.
I believe you may be able to install them, but things like control hardware (either elec, or mech) will be on the wrong side.
You probably can survive a few days with it swapped however.
Non power passenger and driver side seat swaps are not a big deal. Your slider and seat back controls are reversed but everything bolts up no hassle, except (IIRC) maybe for one of the floor bolts on the rear of the slider. When the linen driver's seat bottom finally tore on my NA, I used passenger seat from my parts car for the duration of time until I swapped in lightweight Corbeaus.
