Went to the Dyno 413whp/419wtq
Well I finaly finished having my car tuned for now. Scott Gomes of Under Pressure Performance installed and tuned the Tec3r, I must say he really worked some magic.
This run was done at 22psi tapering to around 20psi. It was 100oct steet legal race gas from the pump, so technicaly you could call it pump gas.
My engine is a 2.8L stroker
Lindsey Racing stage 2 solid lifter head w/ 274 solid web cam
Turbonetics 60-1 hifi w/ stageV turbine wheel and .50a/r t4 turbine housing
Electromotive Tec3r
Numbers in title are uncorrected here a graphs for both corrected and uncorrected.
I will making a few small changes in the coming months to complete the system, I hope to make some small gains up top with these.
Electromotive Tec3r
nice numbers, personally I think your turbo is a little undersized, I have that on my 2.5 (just a turbonetics similar sized turbine housing difference)... more should be had at that boost. The torque curve kinda dies quite early...
On pump gas around 17psi on the street this turbo is amazing.
Former Vendor
Nice results. Converting these ( SAE corrected ) numbers to flywheel hp and Newtonmeters gives roughly 462fwhp and 551 Nm. That's close to 997t, and it's heavier.
What's really impressive, 406 Nm ( 300 lb-ft ) between 3600-6600rpm. With one fixed wing turbo. 22PSI = 1,5bar.
Yes you must get some decent acceleration out of that tq curve.
Pete, have you fired up yours yet?
Patrick
Patrick
Originally Posted by BKiller
Excuse the newbie question but why is the graph so jagged compared to all the others I see? Just the dyno?
NICE! agree 100% on smaller turbo choice. quick spool and good power in mid far preferred to having everything up top for multi use.
Until you own a car that does not come alive until 5,000rpm it is hard to comprehend how unpleasant, frustrating and disapointing it is to drive on the street. Excellent choice, I want a ride
Good stuff. I'm using a smaller turbo for my 3.0 build. My 2.5 car didn't have much till 4K and I didn't like it. The lag at the track was frustrating. You have a nice powerband. That car must be a blast to drive.
George
George
