so I have to remove the crossover to do a clutch job, huh?
Old 04-28-2007, 04:56 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
Default so I have to remove the crossover to do a clutch job, huh?
and I'm assuming that means removing the intake manifold, and undoing everything I just did with the turbo...
damnit...
Old 04-28-2007, 04:58 PM
TRP951
TRP951's Avatar
you shouldnt havt to remove the xover since yours is a s so all you need to do is remove the wastegate elbow.
Old 04-28-2007, 04:59 PM
Mighty Shilling
Wax On, Wax Off
really!? you're serious?
Old 04-28-2007, 05:01 PM
TRP951
TRP951's Avatar
yeah the later 951 have 2pc xovers and since yours is a later one you should have it. The early ones the wastegate elbow is part of the xover and not removable
Old 04-28-2007, 05:05 PM
Mighty Shilling
Wax On, Wax Off
Huh... so I get to save time and money on exhaust/intake gaskets? so I only need the wastegate and downpipe crush rings?
Old 04-28-2007, 05:07 PM
TRP951
TRP951's Avatar
yup and you will need the wastegate donut too since you have to remove the elbow
Old 04-28-2007, 05:10 PM
Mighty Shilling
Wax On, Wax Off
that's good news. I like saving money and time...
Old 04-28-2007, 05:37 PM
5speed300
5speed300's Avatar
Are you going to be doing this clutch job yourself? Have you ever done one before?
I'm curious because I think I have one coming up soon and I dont feel like paying 1500 in labor.
Old 04-28-2007, 07:38 PM
Mighty Shilling
Wax On, Wax Off
I'm going to do it myself, I did one on my 924S with the engine out of the car, so this will be my first time with the engine in... not looking forward to it, but, definately won't be paying $2,000.00 in labor (bills at 20 hours on a turbo)
Old 04-28-2007, 08:14 PM
xsboost90
xsboost90's Avatar
well- you dont need to replace the gaskets on the wg pipe, mine is fine and i got it all used. Its not a paper gasket! Pull the pipe next to the cat, pull the wg w/ the small second crossover piece, do the clutch and then put it back together.
Old 04-28-2007, 08:16 PM
Mighty Shilling
Wax On, Wax Off
sweeeeeet... glad you chimed in before I ordered them Dan! eh, oh well.
so I've been thinking, while I'm in there, I might as well gut the cat....
Old 04-28-2007, 09:45 PM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
that sucks dude. I'm worried about my clutch too, It still feels good, I'm just worried.
Old 04-28-2007, 09:52 PM
5speed300
5speed300's Avatar
Same. Mines not slipping at all, but the pedal grabs at the top of its travel which apparently is a sign its on its way out.
Old 04-28-2007, 11:42 PM
Darwantae951
Darwantae951's Avatar
I just got home and checked out my two picec cross over from SFR...maybe you should do the same, chris! Huh?
-Darwin
Old 04-29-2007, 02:58 AM
Mighty Shilling
Wax On, Wax Off
Basically, the pedal travel is fine. the clutch still has plenty of material left. what it IS doing, the throwout bearing is making odd sounds that change pitch depending on whether or not the clutch pedal is depressed, and, the clutch pedal has varying degrees of resistance, and a "notchy" feeling to the pedal... apparently this is a sign that the throwout bearing is toast, and the grease dried up in the needle bearings in the clutch fork, thus binding on the pivot pin.
so the clutch itself is fine, the bearings to operate it aren't... and while I'm in there... I'll just toss on a new clutch, so it'll be a while before it goes, and I won't need to do this again for a LONG while.
Quick Reply: so I have to remove the crossover to do a clutch job, huh?
