FS: SPEC Aluminum Flywheel
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
SOLD For 944 Turbo, only 800 miles on it. $300 plus shipping. Pics to follow, but here's some info on it:
http://www.lindseyracing.com/Merchan...y_Code=944T951
Question:
What effect did this have on your car's performance? Specifically the throttle response from idle to about 2500-3000rpms in 3rd, 4th, and 5th gear? I have been debating getting an aluminum flywheel because I am conerned with adding unwanted rev up time. Your thoughts please.
I never notice, anyway
I could tell immediately after I got mine in that the car was revving much faster. With the flywheel and the clutch, I lost about 12 lbs of rotating mass.
i don't have an aluminium flywheel, i have a kep 2 and a machined stock flywheel. the engine definitely revs quicker, but be aware that it bogs down a lot more on take-off, so you have to feather the clutch a lot more if you want to avoid that.
Why did you go that way rather than aluminium?
i'd heard mixed reports about the fidanza actually, some ppl claiming that they can warp over time etc. and with the kep as well (which loses quite a lot of weight from the outside of the PP vs stock) i was a bit worried about losing *too* much weight from the driveline and making it a pain to drive on the street.
having had this setup for 2 years now, i'm perfectly happy with my choice. i think with the additional weight loss from an alu flywheel taking off would be a pain...i'm about at my limits as far as that goes
but a lot of this depends on driving style, i don't feather the clutch much on take-off - usually when the clutch is fully released i'm at about 1-1.5k rpm lol.
EDIT: missed a word
EDIT: missed a word
Originally Posted by gcb951
Question:
