Ultra-secret spy shots of the newly-redesigned "Laust vacuum manifold"
Old 03-16-2007, 09:03 AM
333pg333
333pg333's Avatar
Thanks Bill, that's a great image!
Old 03-16-2007, 10:12 AM
sharky47
Set to Full-Auto
sharky47's Avatar
About the vibration, I thought about it - but it shouldn't be a problem. I will test it thouroughly first of course.......
Old 03-16-2007, 10:53 AM
KuHL 951
Hey Man
KuHL 951's Avatar
Is the bore large enough to support the 6 signals? Laust had done some calcs awhile back and determined this was why Porsche went to two banjos on the later Turbo S manifold. Seeing as how several of these vac lines could control more vital functions (KLR, WG, EBC) do you see any issues with pressure differentials caused by them all relying on a single point vacuum source? Not questioning the setup, just wondering. I like the new design, another Sharkey first!
Old 03-16-2007, 10:58 AM
TRP951
TRP951's Avatar
with my setup how it is I only have like 3 lines connected to the vacuum manifold FPR, BOV, EBC if you include the KLR banjo then 4
Old 03-16-2007, 11:02 AM
sharky47
Set to Full-Auto
sharky47's Avatar
Well, the stock vacuum line is 2mm I.D. - which is .079
The hole I drilled in the manifold was almost .200, and I have a little more room if I wanted to make it a little bigger.
Old 03-16-2007, 11:03 AM
sharky47
Set to Full-Auto
sharky47's Avatar
Oh yeah - since this thing is aluminum, what colors would everyone want when I get them anodized?
Old 03-16-2007, 11:06 AM
ivai
ivai's Avatar
Daniel,
I think this will be a great product and something that will help clean up a lot of rennlisters' cars. I know that you said Laust's original design would be hard to do mass production of, but I would urge you to revisit this and see if you could find a way to make it fit flush against the intake manifold.. I think it looks much cleaner that way and close to stock.
My .02
Old 03-16-2007, 11:54 AM
ibkevin
Defending the Border
Rest In Peace
ibkevin's Avatar
Ahhh, Dan,
This is nowhere close to Laust's VM, I would avoid misrepresenting your manifold by attaching his name.
Old 03-16-2007, 11:59 AM
sharky47
Set to Full-Auto
sharky47's Avatar
Uhhhh, ok - had to call it something yall would recognize. And I did make it clear it was redesigned.....whatever......
Figured I would come up with a name for it by the time it goes into production......
Old 03-16-2007, 12:00 PM
Darwantae951
Darwantae951's Avatar
There shouldn't be any issues, as he does state in the title that it is "Re-designed."
Hey Dan, Looking good! How long will you test it before you sell it?
-Darwin
Old 03-16-2007, 12:04 PM
sharky47
Set to Full-Auto
sharky47's Avatar
Don't know just yet - hopefully I can get some machine time soon to get the body blanks made. Then I have to make the air fittings, then I have to crossdrill/crosstap the holes on a secondary mill, then I have to anodize them.........whew........that's alot of work!
I am moving as fast as I can. Hopefully soon I will have enough volume to justify phasing out my dayjob and doing this fulltime..........
Old 03-16-2007, 12:19 PM
Darwantae951
Just curious, if you phase out your day job, how will you make your parts? Contract your current employer for machine usage?
-Darwin
Old 03-16-2007, 12:34 PM
sharky47
Set to Full-Auto
sharky47's Avatar
I will start buying into the machines.
Old 03-16-2007, 01:08 PM
2bridges
2bridges's Avatar
Hey Dan. Looks good.
Contrary to a few I much prefer this design to the laust manifold's home-made look.
As for anodizing - my preference wuld be NONE! is already aluminum, that would be my preferred finish. Folks could always polish.
question: is final product intention to use plastic nipples? or machine also?
I will be a testing guiene pig if you need one.
Would suggest four port and six port.
four port makes sense for the simple add of boost guage/ boost controller.
Old 03-16-2007, 01:12 PM
sharky47
Set to Full-Auto
sharky47's Avatar
2bridges, I can always anodize them clear.........just keeps them from oxidizing.
As for the nipples, they will be machined out of hex brass so you can tighten them down with a deep socket.
They will all be six port, I will provide six nipples and two plugs - use them however you see fit. It's actually easier cheaper this way, even throwing in the extra plugs/nipples - I only have to write one set of programs......
Quick Reply: Ultra-secret spy shots of the newly-redesigned "Laust vacuum manifold"
