Laust's Vacuum Manifold GB
Old 03-10-2007 | 01:55 PM
Darwantae951's Avatar
Darwantae951
Default Laust's Vacuum Manifold GB
Hey guys, I was looking to buy one of his 5-port two banjo bolt vacuum manifolds and sorta sparked a renewed interest in his VERY nice product. I'm not sure of the exact construction and maybe he can chime in as far as that. The options as far as VMs is as follows:
4-port single banjo
5-port single banjo
5-port double banjo
If there are any other variations I'm sure he'll post them. I'm ordering a 5-port double banjo VM. Laust, could you please post your current supply so I don't mess things up and say you have more than you actually do!
-Darwin
Old 03-10-2007 | 02:09 PM
KuHL 951's Avatar
KuHL 951
Hey Man
I would like a 5-port dual-banjo VM if there are any left. It worked great on my other 951 and allows for better vac line routing and equipment. Just let me know when and how to pay.
reno808's Avatar
reno808
I already pm him about it
Old 03-10-2007 | 02:24 PM
Darwantae951
In his response to the origional thread he said he had 4 5-port dual banjo bolt VMs left, so theres enough for the three of us. That makes only 1 5-port dual banjo VM unclaimed. As long as laust recognizes this. Heres a list:
Bonestock951s - 5-port dual banjo
KuHL 951 - 5-port dual banjo
reno808 - 5-port daul banjo
That sound correct?
BTW, both of you have early 951s, why do you need the double banjo version?
-Darwin
Old 03-10-2007 | 02:44 PM
KuHL 951's Avatar
KuHL 951
Hey Man
Originally Posted by Bonestock951S
...BTW, both of you have early 951s, why do you need the double banjo version?
-Darwin
I use the 2 banjo bolts for the KLR and a dedicated boost gage. The other ports were used for the venturi delete with no spares. I eliminated all the plastic tubing under the hood on mine.
Old 03-10-2007 | 02:50 PM
Darwantae951
Did you drill another hole into the intake manifold?
-Darwin
Old 03-10-2007 | 03:44 PM
billthe3's Avatar
billthe3
I'll take the 5 port single banjo if he still has one available. I'm pming him about it as well.
Old 03-10-2007 | 03:48 PM
Darwantae951
billthe3 - 5-port single banjo
And the list continues...
-Darwin
Old 03-10-2007 | 03:57 PM
reno808's Avatar
reno808
Bonestock951s i am taking the 4port single banjo because he only has one left and i dont have an s in order to put a double banjo in there
Old 03-10-2007 | 05:21 PM
5speed300's Avatar
5speed300
I am going to be getting a 5 port single banjo bolt from Laust.
However, he pm'ed and said that he does not currently have any of that type left and that I would have to wait until he made a new batch of manifolds if that is what I wanted.
So anyone looking for the 5 port, single bb will have to wait.
Old 03-10-2007 | 07:00 PM
KuHL 951's Avatar
KuHL 951
Hey Man
-Darwin
Thanks for the heads up, I've never owned one past an 86. The black car has a later manifold on it. The project car is a stock 86 manifold that I've already polished. Change mine to a 5-port single if you still can. It's not worth swapping. I'll split a vac line if I have to but I should be OK.
Old 03-10-2007 | 07:45 PM
sharky47's Avatar
sharky47
Set to Full-Auto
Laust has contacted me about passing the production off to me. I told him that I wanted to take it on, I will asses the project hopefully later tonight.
This is all still up in the air, so anything is subject to change. I am excited about offering another product though, I should be able to make them in volume...........
billthe3's Avatar
billthe3
Schweet.
Old 03-10-2007 | 08:00 PM
Rock's Avatar
Rock
Lazer Beam Shooter
Damn Sharky youre on fire!
Old 03-10-2007 | 09:31 PM
5speed300's Avatar
5speed300
I dont think you can go wrong with these things. They cant be that expensive to produce if Laust was selling them for 25 bucks, and obviously there is mucho demand for them.
Quick Reply: Laust's Vacuum Manifold GB
