Interesting article on new oil standards
Not mine, but thought it's an interesting read.
Oil is Killing our Cars
By
Keith Ansell, President
Foreign Parts Positively, Inc. www.ForeignPartsPositively.com
360-882-3596
Oil is Killing our cars Part I
About a year ago I read about the reduction of zinc dithiophosphate (ZDDP) in the oils supplied with API approval that could affect sliding and high pressure (EP) friction in our cars. The reduction of these chemicals in supplied oil was based on the fact that zinc, manganese and/or phosphates reduce the effectiveness and eventually damage catalytic converters and introduce minute amounts of pollutants into our atmosphere.
A month or so ago I had a member of the Columbia Gorge MG Club bring a totally failed camshaft and lifters back to me that had only 900 miles on them!! I immediately contacted the camshaft re-grinder and asked how this could happen. They were well aware of this problem as they were starting to have many failures of this type. In the past, the lack of a molybdenum disulfide camshaft assembly lubricant, at assembly, was about the only thing that could create this type of problem. My customer has assembled many engines and had lubricated the camshaft properly and followed correct break in procedures.
This got me on the phone to Delta Camshaft, one of our major suppliers. Then the bad news came out: It’s today’s “modern” API (American Petroleum Industry) approved oils that are killing our engines.
Next call: To another major camshaft supplier, both stock and performance (Crane). They now have an additive for whatever oil you are using during break-in so that the camshaft and lifters won’t fail in an unreasonably short period of time. They also suggest using a diesel rated oil on flat tappet engines.
Next call: To a racing oil manufacturer that we use for the race cars (Redline). Their response: “We are well aware of the problem and we still use the correct amounts of those additives in our products”. They continued to tell me they are not producing API approved oils so they don’t have to test and comply. Their oils were NOT the “new, improved and approved” ones that destroy flat tappet engines! “We just build the best lubricants possible”. Sounds stupid, doesn’t it, New-Approved but inferior products, but it seems to be true for our cars.
To top this off: Our representative from a major supplier of performance and street engine parts (EPWI) stopped by to “warn us” of the problem of the NEW oils on flat tappet engines. This was a call that the representative was making only because of this problem to warn their engine builders! “The reduction of the zinc, manganese and phosphates are causing very early destruction of cams and followers”. They are recommending that, for now at least, there must be a proper oil additive put in the first oil used on new engines, beyond the liberal use of molydisulfide assembly lube. They have been told that the first oil is the time the additives are needed but remain skeptical that the first change is all that is necessary. Their statement: Use diesel rated oils such as Delo or Rotella that are usually available at auto stores and gas stations.
This problem is BIG! American Engine Rebuilder's Association (AERA) Bulletin #TB2333 directly addresses this problem. I had a short discussion with their engineer and he agreed with all that I had been finding.
Next phone call was to a retired engineer from Clevite, a major bearing and component manufacturer. First surprise was that he restored older British Motor bikes. The second surprise was that he was “VERY” aware of this problem because many of the old bikes had rectangular tappets that couldn’t rotate and are having a very large problem with the new oils. He has written an article for the British Bike community that verify all the “bad news” we have been finding.
Comp Cams put out “#225 Tech Bulletin: Flat Tappet Camshafts”. They have both an assembly lube and an oil additive. The telling sentence in the bulletin was “While this additive was originally developed specifically for break-in protection, subsequent testing has proven the durability benefits of its long term use. This special blend of additives promotes proper break-in and protects against premature cam and lifter failure by replacing some of the beneficial ingredients that the oil companies have been required to remove from the off the–shelf oil”.
Next question: Now what do we do?
From the camshaft re-grinders (DeltaCam): “Use oils rated for diesel use”, Delo (Standard Oil product) was named. About the same price as other quality petroleum based oils. They are not API formulated and have the zinc dithiophosphate we need in weights we are familiar with. From the camshaft manufacturer (Crane): “use our additive” for at least the first 500 miles.
From General Motors (Chevrolet): add EOS, their oil fortifier, to your oil, it’s only about $12.00 for each oil change for an 8 ounce can (This problem seems to be something GM has known about for some time!).
From Redline Oil: Use our street formulated synthetics. They have what we need!
From our major oil distributor: Distributing Castro, Redline, Valvoline and Industrial oils: “After over a week of contacts we have verified that the major oil companies are aware of the problem”. “The representatives of the oil companies today are only aware of marketing programs and have no knowledge of formulation”. The only major oil companies they were aware of for doing anything to address this are Valvoline that is offering an “Off Road 20W-50” and Redline.
From Castrol: We are beginning to see a pattern emerging on older cars. It may be advantageous to use a non-approved lubricant, such as oils that are Diesel rated, 4 Cycle Motorcycle oils and other specified diesel oils.
Last question: So what are we at Foreign Parts Positively going to do? After much research we are switching to Redline Street rated oils and stocking the Castrol products that are diesel rated. Castrol, owned by British Petroleum, is now just a brand name. This is a difficult decision as we have been a dealer and great believer in all Castrol Products for over 40 years. We have been using Castrol Syntech oil in new engines for about 3 years so the cost difference in changing to Redline is minimal. The actual cost in operation is also less as the additive package in Redline makes a 1-year or up to 18,000 mile change recommended! Yes, it is a long change interval but with lowered sulfur levels and the elimination of lead and many other chemicals in the fuels there are less contaminants in our oil from the fuel, which is the major contributor to oil degradation. We will continue to offer the Castrol products but will now only stock the suggested diesel oils that they produce.
Too many things are starting to show up on this subject and it has cost us money and time. Be aware that “New and Improved”, or even products we have been using for many years, are destroying our cars as it isn’t the same stuff we were getting even a year ago.
For the cars that use “engine oil” in their gearboxes this may even pose a problem as these additives that have been removed could be very critical in gear wear. We will be using oil specifically formulated for Manual Gearboxes with Brass Synchronizers. The only oils we are aware of that fit the criteria are from General Motors and Redline.
If you have any additional input let us know. We need to let every flat tappet engine owner, i.e.: every British Car owner know that things are changing and we MUST meet the challenge.
By
360-882-3596
I have first hand experience with one such failure. New 406 small block chevy. Crane Cams flat tappet.
After 1600 miles - flat tappet cam started coming apart - lifters and cam began eating each other. I was 900 miles from home towing a heavy trailer with a 4000lb car.
long stroy short - drove the trailered car and truck with empty trailer home - stopping periodically to pull valve covers and adjust lash out of valvetrain. Ran in top gear in peak torque area to limp it home with least total revolutions... was a total nightmare.
I had built nearly a dozen engines without any failure issue. Had a long discussion with machinist. $2500 later roller cam with hardware..
Is a real nightmare when it happens to you.
So to some it all up... Should we not use over the shelf oil from places like autozone??? and instead go with redline or other products?? And is this for only breakin in engines??
I don't know the answer, I thought it was of interest for sure. I do know for example in speaking with the local Mobil One rep (Canada) the formulation in the US is very different than in Europe. This change happend a few years ago and may explain the poor ratings Mobile has had of late.
I mostly use Rotella T synthetic which is a Diesel rated oil and has zinc in it as per the MSDS.
What about STP oil additive? I thought that was mostly thick oil with some high pressure additives?
-Joel.
-Joel.
There is NO QUESTION that Mobil1 is no longer what it once was. Some time ago, after a reccomendation by special tool, I switched to Agip 4T 10W60 4 stroke racing oil. It is designed for racing motorcycles. I get it by the case from Agip USA. Unless they change it, I'll never stop using it.
Hearing of this problem before I use the Valvoline VR-1 20w-50 (non syn) which has adequate amounts of ZDDP for my Callaway turbo. And I use Amsoil syn HP 20w-50 in the NA...235,000 miles and the cam and lobes looked fantastic at 208,000 when I had it apart for a head rebuild.
Why dont any of you use oil from LE ?
I have LE`s SAE50 oil on my car , and as a oil for cars that are not in everyday use it is fantastic. Lower oil temp than other oils I have tested when driving hard, and much less mechanical noises from the engine. Besides it has a more stable viscosity at higher temps ( 120grC + ) .
And not to mention LE`s gear oil , fantastic ...
Hey Ed,
This is where I first saw it. Then I went and did more research, so I posted it on the 944 board. It seems like important info.. As I recall that guy was looking for "cheap oil" lol.
Of all the things we spend money on, I'd bet my last buck neither you nor I mind spending a bit extra on good oil.
cheers.
As I understand it is the lack of certain additives to either. I believe the conclusion was that the deisel blends still have those additives. There is also a Castrol Syntec blend of 5-40 that carrys a label that says it is formulated for MB, Audi and Porsche.
