My 951 Puzzle
#34
[QUOTE=jakery]The car is almost ready for the new turbo, i was tracing the turbo & engine mount oil lines to make a flange. Looks like modern art/QUOTE]
What are you trying to do with the oil line flanges. I think I might have the filter housing too, I have a couple but I need to check the MY on them. Pm if you still need one.
#35
resident n00b
the mount on the bottom of the turbo doesn't match the oil mount on the engine mount arm, so i am making a metal gasket to make sure the two seal properly. Yay loctite.
I think i found a housing, but i'll let you know.
-jw
-jw
#36
resident n00b
Plenty of things.
Wrapped my Exhaust/turbo & Painted with 2000 degree copper paint.
Some one Bred hate on my creeper.
Turbo fits great with the flange i made to fit the TO4E, there is no fitment issues thus far.
I did a rough assembly w/o heat sheilds and with double intake gaskets and the mainfold clears the turbo by 1.5 mm WOO HOO!
How do you like the color? i love it, took me a long time to pick it out. I wanted to make my car a touch unique.
thanks, -Jake
thanks, -Jake
#38
resident n00b
Originally Posted by Cory9584
looks good. but are you sure its ok to double up on intake gaskets?
INTAKE MANIFOLD SPACERS LINK
#39
Originally Posted by JDeitz951
Typical forum-quality advice, "I think it might be true, therefore I post"
The flammable liquids are the fire hazard, not the wrap. If you are driving around in a car that soaks the wrap with fuel or oil, it's a piece of ****, FIX IT!
![nono](https://rennlist.com/forums/graemlins/nono.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#40
"looks good. but are you sure its ok to double up on intake gaskets?"
I am with you cory..... not on my car. I understand why one would do it, but this is not a workaround for me
#41
#42
resident n00b
I wouldn't need to file, just countersink the throtle body return spring bolts.
But i think that vacuum elbow will hit too, that may be a bit of trouble.
There was a intake manifold spacer kit on evilbay for $116,
but i would be worried about sturtbrace clearence.
#44
My stuff!!!
Jake, maybe you can get Hondata to make a run of their honda gaskets for 951's. You can space your stuff out a bit with 1 gasket, and though its not as relevant to turbo cars, maybe take advantage of the heat shielding effect it has. Their re-usable too, so you don't have to port match new gaskets to the ported head/manifold every time you pull the intake off.
http://www.hondata.com/heatshieldgasket.html
