2.8 liter
It'll be a few thousand to build one - source a 3.0L S2 or 968 crank and then have the bottoms of the cylinders notched to accommodate the movement (it'll hit if you don't). Once that's done it's pretty much conn. rods and basic assembly. I was looking at doing this on my Callaway turbo - estimated it would be about $6,000 when all was said and done - but I'd be doing all the work (except for machine shop work) and assembly myself.
2.8 pistons, 1000
Carillo or Pauter rods 1000
crank 1500
bearings, seals, gakets, 600
head refresh, mild P&P, 1100
clutch to handle it all 850
misc sensors, **** I broke that 500
Turbo, MAF, injectors, software 3200 - 4900
WBO2 500
exhaust 1500
belts, rollers, water pump 500
all figures are rounded off, delete if you already have any of the above items. Your labor of course.
crank 1500
WBO2 500
exhaust 1500
2.8 or 3.0 liter turbo!
Ski is right on the money, by the way thanks for Tom Charlseworths info he made me a set of 104mm low compression pistons for my project.
Building 3.0 liter and 2.8 liter motors cost about the same in the long run IF you do all the legwork yourself and PLAN on spending at least 3 months tracking, searching, scowering, and begging to assemble all the neccesary parts, information, and software to get your motor done right the first time. And if this is your first time your going to make mistakes just try to take all the info in that you can handle! Good luck!
Originally Posted by damiza318
how much does it cost for a 2.8L engine and where can I find one? Is it possible to get a 2.8 stroker or bored out engine in my car for that? and if it is possible within that budget, which way do you suggest I should go? what is the most cost efficient and reliable in terms of longevity or the most bang for the buck? also, do you know of anyone in the tri-state area or the northeast who specializes in that type thing and can point me in the right direction?
With the rebuild of my broken motor, it needs pistons, line bored, cylinders redone, bearings, gaskets, new clutch. Parts come to about $5000 if I keep it 2.5 Liter. Since I already have a big enough turbo, pauter rods, MAF, etc., the only difference in cost for me will be the crank. Of course that is going to cost me $2500 instead of $1500 because I just can't bring myself to put it in without having it lightened.
Oh yeah, that also includes extrude honing the intake, and coating the pistons and exhaust.
