Looking for Motons-JRZ-Penske
#31
If you look at the downloadable PDF instructions, you can see pics of the rear coilover. It's a neatly mounted with lower shock body offset to clear the trailing arm. The spring rates seem to be set up to retain the torsion bars.
http://www.kw-suspension.com/en/30_P...pe=all&zeile=1
http://www.kw-gmbh.de/kw_upload/Einbau/eah68671010.pdf
#32
Originally Posted by daigo
Hi Karl,
Yes it was KW North America. First it was the previous rep here in Canada, then the new one in the US when they took it over. So I did give it a fair try.
I still feel comfortable using them for a street application because its a standard part, so the only real support I need are warranty/repair services and I'm sure they'll have that covered.
Karl.
#33
Karl you won't be disappointed.
#34
The KW's are a great product and probably the best upgrade for a street car. As for racing, thats different, the produt becomes much more bespoke and is all down to setup so I agree there.
#35
I have driven on KW's many times before and they are great products. As with others, when I approached KW NA and associated vendors. they were of little help sorting out the suspensions. By the time I would have had 2-way adjustable KW's, I was already in what the 2812's were going to cost me and Koni seemed to have a much better customer service team. I have since gone with Brett at www.performanceshock.com out of California. Costs me more to ship it, but he has been more than helpful with my setup. I have spent probably 10hrs on the phone with him, and he does nothing but offer information. Even helped design my custom (bespoke) front dampers. He also sells Ohlins, Penske, and others. I would be happy if there was enough interest to try to put together a nice high end suspension GB.
Wes
Edit - I have also worked with Marcel at HPA Motorsports in Canada on many occasions. I would be glad to ask him about a KW V3 group buy, but he would probably do no less than 10 paid orders at the minimum. He was the NA representative, although I think it has changed now.
Wes
