Christmas came in a LR box!!
Hey guys, I got the LR MAF stage 1 for christmas and was wondering if it can be used in place of the stock air box w/o needing any new parts or modification (other then installation). I got the Stage 1 because im doing a GT30R swap and the 26/6 tubing may have been useless.
If i cant put it on now then that just gives me a reason to get the gt30r sooner.
I have Powerchips chips (dont know if that matters).
TIA
-Jace
TIA
-Jace
It is the stage 1 so its only the filter and Maf. Does not include anything else.
![](http://i28.photobucket.com/albums/c214/supraspyder420/951MAF1LL.jpg)
So other then tubing/adapters, the MAF hould just replace the original airbox/afm w/o any other changes right?
You should need either chips mapped for it or a piggyback type system to regulate fuel.
Looks like you're lacking the tubing to mate it with the turbo unless it somehow uses the stock stuff.
ok thats what i was looking for. Guess i will have to wait to put it on until i have the turbo and other stuff on.
I didnt want to buy the stage 2 because then i would be paying an extra $300 for a tube/adapters that i may not be able to use with the gt30r.
Do you need a chip for the MAF if you are running a SMT-6?
Small Business Partner
Originally Posted by HIGHBOOST
You should also purchase the lindsey chips that are mapped the their MAF.
Rogue
Drive-by provocation guy
Well, without the tubing/pipes, you can mount the MAF in the stock AFM location.
If you want to run it behind the headlight like many do, you will need some adapters/tubing.
I have mine right where the stock AFM was and no issues.
I dont want to buy the LR chips because i will be doing turbo, injectors, etc... and dont want to buy another chip when the mods are done.
Maybe its time to buy russels maxtronic?
