UK 3.2 Turbo hits the road
#526
Paul, Your car is looking awesome. Great job bringing LIL back in shape. The black contrast makes it look aggressive.
#527
My vote is to paint the mirrors to match and add some 968 door handles, also to match the car. Leave the wheels black. Since my car is the same color, I'm a little closer to your car now!
#528
Paul, the car looks sharp with the new mirrors on it. Personally, I would paint them to match the rest of LiL. And if you don't track the car, do you think you will have a chance to dyno her?
#529
Paul I like the black theme, but they would also look great matched to the body colour. Those mirrors are a really nice upgrade for our car cosmetically IMHO.
What's this about having to fix the OPS and W/B? Are you driving the car still? What sort of psi have you been pushing?
#530
Formula One Spin Doctor
It strongly appears so. My 87 is the same color, though the sticker says "OCEANIC" blue. The same code is listed as "Nautic" blue, in 87', and then there is "Baltic" blue. They are all named after water and my research shows that they are al the same color. It makes no sense, but that's what I've been able to discover, over the last couple of months.
#534
That's why I jumped on this one. We got very few. Hell I don't think they made very many. I've seen lists, and this color is always low on the pole.
The pic I posted isn't as accurate. My car looks identical to "LiL", in the same light.
#535
Jon M did some work on the timing and richened up my fuelling just a tad so that I don't have a recurrance of melting the plug on cyl#4 when I am next on track. She dyno'd at 350HP and 420ftlb after the changes and is definatley a bit nippier as she has started to slip the clutch between 3500rpm and 4500rpm if I run at 18psi. For that reason I am running at 15psi for the time being until we change out the cup clutch for one that can handle more torque
#536
We had Nautic blue (aka Ocean) over here in 1987 as well and it is coded as LY5Z
Mine is Baltic blue (aka Dove) from 1989 and is coded as LM5P.
I've seen both colours side by side and mine has a lot more silver fleck in the mix
#537
I would be interested to know how & where said valve is fitted.
#538
Looks nice Paul, keep pushing through all those little jobs. Hopefully we will get a chance to do some comparative testing soon!
BTW personally I would paint the mirrors blue.
#539
Yes, Simon from SPS made it and it was fitted to the turbo oil supply before it's return. I'd been experiencing a small amount of oil smoke on the overrun and at idle and the reduction in pressure to the turbo has cured it. The Garret spec was 2bar for this particular model
