NKG BPR6ES or 7 ES?
I was using the Bosch Super Copper Plugs WRC7's and I pulled them out and they were black, this is probably why it was backfiring. I bought some NGK BPR6ES and immediately noticed a difference, it runs a lot smoother and no more backfiring, however, I noticed that the temperature gets hotter, almost up to the top white line when at a light. I was reading up on the threads here and alot of you guys use the 7's. I use my car for the street, it's not a daily driver and it's driven mostly on the weekends. My question is, should I switch to the 7's or keep the 6's? I have a MAF by Pro Flow Tech and the MBC boost is set to 12 psi with a 3 bar FPR and 3" exhaust with Borla muffler.
Basic Sponsor
Try NGK BPR7ES , one range colder.
Ditto. 7's. Running 1bar with and without a maf I used to see a bit of misfiring on the top-end with the 6's occasionally. There isn't any reason why the difference in heat range between 6's and 7's should cause your car to run that much hotter, so I think you might want to check out your cooling system to see if you have any issues there.
What he said.
One range on the plug won't make a difference in how hot your car runs. 'Hotter' refers to spark energy not an actual temperature.
Originally Posted by LFA951
I have no coolant leak issues, had one two months ago, but Bar's stop leak fixed it...
Is that a liquid you poured into the coolant to stop leaks? If so, I bet that is your problem.
Those liquids will coat and clog the coolant passages as well as the inside of the radiator greatly reducing efficiency.
Drive-by provocation guy
Flush and drain and then find and fix the leak.
If this does not get addressed you can blow your head gasket with an overheating system.
Originally Posted by toddk911
Yep! Those pour in's are meant to be a temp fix.
It may be too late late for a flush. Once those stop-leak liquids harden, you can't clean them with a flush.
Have you seen coolant passages fof an engine that have been that crap? They look like cross section of a blocked artery; filled with a yellow-while calcium like deposits.
Originally Posted by beab951
Well not quite, the heat range is a measure of the spark plug's ability to remove heat from the combustion chamber.
Sweet mother of God! I just noticed you have over 17,000 posts!
The temperature was fine when I had the Bosch Super WRC7's, it only chqanged when I switched to the NGK's...
UAE Rennlist Ambassador
The factory recommends the 7 range (cold), never go to a hot range (6 and below).
BPR7ES works great, even in the hottest of climates IIRC, better than that WR7DC from Bosch.
