Carbon removal on pistons while in the block
I've searched and found multiple opinions on why not to use a bunch of different products/methods....but haven't really found one (mostly) agreed upon method. Have any new products or opinions surfaced as of late?
Cleaners:
Oven cleaner
Simple Green
Glass cleaner for stoves/furnaces
Carb cleaner
etc...
As far as applicator(s) I'd like to stick w/ the paper towel route just because the wire brushes/wheels/Scotch Brite etc... seem a little bit too aggressive for what I need to do. I do have a fare amount of build up but nothing out of the ordinary for a 951 w/ 100k (PO had Autothority chips ?-80k; I've ran Guru 15psi chips up until 100k).
Thanks!
Cleaners:
Oven cleaner
Simple Green
Carb cleaner
etc...
Thanks!
The carbon on my pistons was very hard -- paper towels would have taken forever and all the pulp, etc. would quickly be a mess. I used simple green and various solvents with Scotch Brite -- protecting the ring ridge with paper towels and then blowing compressed air and vacuuming several times before buttoning it up. Even that took me several hours of tedious cleaning.
Wipe with Coke or Pepsi and remove the residue with a piece of wooden baton.
Carb Cleaner can leave residue on bores
Cleaners:
Oven cleaner
Simple Green
Carb cleaner
etc...
Thanks!
Cleaners:
Oven cleaner
Simple Green
Carb cleaner
etc...
Thanks!
Thanks for the quick replies gang.
EO,
higher comp and detonation
Tom,
Yup, I imagine this will take hours of elbow grease to do...what grade of ScotchBrite pad did you use? PS I've been referencing your headgasket and turbo R&R write ups for most of the work I've been doing. Great work and thanks!!!
Tommo,
I know colas will eat through lots of stuff like tooth enamel in less than a week if soaked in it but do you have experience using it?
Eyal,
Yup that's what I'm worried about.
EO,
Tom,
Tommo,
Eyal,
EO,
I know this but you have more chance of getting carbon or dirt in the rings an messing up your cyl walls than you do have det problems because you left it.IMO
E
E
Turn the crank till all the pistons are some what in the middle of the bore and fill them all up with brake fluid. Im a porsche tech and beleve me this works. Try to leave it in there for a few days and it will start to brake up the carbon on top. some of it will leak pass the rings but, you are going to drain the oil anyway. try to keep it toped off. Good luck.
I was going to suggest a carbon remover like sea foam, turn the engine until 2 pistons are just past TDC, about 1/2-1" down from the top, then clean the pistons. Next rotate the engine so the pistons are moving down, clean any remaining grit from the cylinder walls as the piston moves down, this way it won't get stuck and scratch the bores. When done do the other 2 cylinders.
I actually use the standard green scotchbrite-- like the kind on the back of sponges at the supermarket. I'd try some of the carbon removers recommended here -- Simple Green takes a long time, carb and parts cleaners are only a little better, but made me light-headed as I stood there and worked on the pistons. If memory serves, my hg write up starts with a picture of the freshly cleaned pistons.
Carbon also heats up and creates hot spots and/or little glow plugs in the cylinder -- not good at all. If you're careful, you can avoid getting debris in the rings. Mine's been fine since the cleaning for example.
Tom,
Yup, that's the detonation source I was concerned w/ above reply (glow plugs). Thanks for all of the replies gang. I should be digging into this sometime this week/weekend...I'll post how things turn out.
