RWHP Numbers for Vitesse Stage 2 at 15-18psi on 2.5L
I'd like to hear what people are putting down to the wheels with their Vitesse Stage 2 turbo, running between 15 and 18 psi on pump gas and on a 2.5L. I'd also like to know at what rpm you're reaching 300 ft-lb at the wheels. Some of the plots on John's site do not state what boost levels the runs were made at.
My T04E hybrid (0.6 A/R, 3" inlet) put down 311rwhp at 16psi and 325rwhp at 18psi, running a 57 trim compressor wheel (56.6mm inducer / 74.9mm exducer). I reached 300 ft-lb torque to the wheels by 3700rpm. With a 60 trim wheel (58.2mm inducer / 74.9mm exducer), it hit 325rwhp at 17psi, but didn't reach 300 ft-lb to the wheels until 4100rpm. The turbine housing is a KKK #8, but I'm not sure what turbine wheel is in there. I'm considering a Vitesse Stage 2 turbo, but only if I'll see significant improvements with it.
Thanks!
- Ian
Thanks!
- Ian
Here is the original thread with mine.
https://rennlist.com/forums/showthre...25#post2464425
**CORRECTION: My turbo is a Stage III - not a Stage II **
jwl's 2.5, at 15psi, 2500 miles after rebuild, made 310/322 but we found an exhaust leak. Never dyno'd it again and two years later it was a 2.8L.
VRSTAGE2, I'd still like a photo of that engine for our book, being JAB Racing built it
JWL had the older stage 2, VRSTAGE2 has the newer one. Not the same turbo, but close enough. The new turbo supports about 40-50more BHP and spools a tad quicker.. Both are great performers.
I recently made a few changes to the Stage 2 so it spools up even quicker, which equates to more torque and a wider power band.
VRSTAGE2 isn't this the dyno chart that you sent me? VR S2 Pump Gas
Soloracer, you have the Stage 3 not Stage 2.. Also, I just looked at your chart, something is not correct with your setup.. Compare your run to others (same kit as yours), it's not the same.. Take it off line if you want to discuss further.
Rolex : Don't make assumptions. They just used different scaling for the TQ/HP curves. Take a look at the value for the torque at 5250 and then take a look at the value for the HP at 5250. They are the same. So if the scaling was the same for both HP/TQ they would cross at 5250 as they should. There is nothing wrong with the chart. We dyno'd 10 cars that day and they were the same. Just because the results were not what everyone expected doesn't mean there is anything wrong with the chart. I've heard it all "the dyno operator doesn't know what he is doing" or "you have an exhaust leak", etc. The dyno operator does know what he is doing and we checked for exhaust leaks and found none. I'm open to suggestions but these were the actual results and they are as accurate as any out there.
P.S. If you are unsure how to read the graphs maybe this will clear it up for you: the bottom curve is the HP curve. Go to 5250 on the bottom and then go up to where you would hit the bottom curve. Look to the left side and see that the value is approx 285. Now find 5250 again on the bottom and this time keep going up until you hit the top curve. Now look to the right to see what the value is. Surprise! It's 285 as well - just like it should be. Nothing is wrong with the chart.
Good luck with that car too, its fabulous!!
