Can ISV leak?
Can ISV leak?
I have a HUGE vacuum leak! It is coming from the isv area. My vacuum at idle is about 7. I just changed the tps yesterday. Right now my car isle idling like ****. On my way to work tonight the engine would rev to around 3000rpm and stay there on its own. I am going to dig into this bright an early tommorow. My questio being, can the isv leak itself. Or would one of the hoses be a more likely cause? I replaced all vacuum lies this summer and did a venturi delete. the only lines i didnt touch were the ones on the isv! (bad move). Im guessing its more than likely the lies trhan the isv!
thanks for the responses.
I sure hope so! Because i NEED to fix this in a couple hrs! Time for a speed ru on the IM! This will be the third time. I give myself a 1/2 hour to have it off!
Yes ISV's can leak...hoses too
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/271337-intake-system-pressure-test.html With PIC's!
This may sound intuitive but simplest way to determine the cause of the leak is to put a piece of rubber hose up to your ear and put the other end on the source of the whining/whistling. It sounds like you have done something like this already.
My ISV was replaced last week and while it wasn't making any noise or causing a vac leak, it was the causing idle problems.
