Need some "big bore" advice
#31
Oh Rob forgot to mention, if you read my post I said there were probably better pistons than JE, and then gave some possibilities. I also clearly said which I used and am happy with.
Again good luck on your search, I have talked to the people I mentioned, but their comments and beliefs are their's to make so I'll let you decide for yourself.
#32
Well, pistons are trashed bad (i'll post pics when i can), but the liners now that i have the block totally bare isn't bad at all. My machinist says he wants to take .010 off the bores to get the scratches from the pistons off, then hone them to a new set of pistons. I talked to ebs, the biggest set they have is 4.104 on the shelf, but the .010 he's taking off will put the biggest bore to 4.106. He told me to look for 4.110 pistons so that it gives him some clearance to work with. So is there anyone else i can call up for a set of pistons? Someone mentioned wiseco and that they run closer tolerance, any specifics on just how much tighter they are?
#33
4.104"? That works out to just under 104.25mm. Dont they have a set of 104.5mm jugs? Those would come out to aprox 4.110" I thought these were available, just not the 104's. Call Andial if you get a chance as well since those pistons look like the solution you need.
Other than the Mahle's, I dont know of any true alusil-capable piston available on the open market (?).
BTW, I envy where you live - Love Taos in the winter!
#35
#36
#37
Good luck
#38
Ah, yes, sorry red. Well, It may be a wait then.
Oh, and I dont have emissions testing on any of my cars either. I just happen to live in one of those agricultural zip codes in California . Haven't had a smog test in 2 years
Keep us posted on how this goes and watch those gauges.
Brendan:
I was running the Swain coat on the skirts of my stock pistons in the red car before I took it down to part it. 10K miles and really good compression #'s. Did Dave say it was Swain coatings as I had been told they are using some similar plasma process but not Swain's directly? All coatings are not created equal (or equally endowed as I like to think of it). John Anderson used to use this rattle-can shiet on his builds and we know how many of those went. [source: out of his own mouth standing in his now defunct shop.]
Brendan:
#39
Yes, Dave mentions Swain on his website as the coating company. It really seems to be working.
#40
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Hmmm….I will be out in Santa Fe later this week for Christmas. Interested in a second opinion?
BTW - I can order up JE pistons in any size you want – that’s what a custom piston is all about. I also have a system for calculating the correct dish volume – if you just ask for stock dish the CR will change a great deal as the diameter goes up.
Chris White
PS – I had lunch with Jack Sparks last week…..
Chris White
#41
Originally Posted by Chris White
Hmmm….I will be out in Santa Fe later this week for Christmas. Interested in a second opinion? BTW - I can order up JE pistons in any size you want – that’s what a custom piston is all about. I also have a system for calculating the correct dish volume – if you just ask for stock dish the CR will change a great deal as the diameter goes up.
Chris White
PS - I had lunch with Jack Sparks last week…..
Chris White
dand86951: Thanks for all of your help and suggestions pal, I do appreciate it. And yes, as I know there are better pistons out there than J&E, hence, more of a reason I/we need to hear what Chris thinks more so since he went to that show.
#42
As for pistons I know that the shop in California (CMW) that knife edged and lightened my crank was mainly into high performance 911's. They were testing carbon fibre pistons. Now those would have been crazy.
#44
Chris White
Chris White
