Possible electrical problem
I noticed a couple of weeks ago that my interior lights did not come on when I open the drivers door. Works fine from pass. side. I did a search for "interior lights" and found a couple of threads on the issue:
https://rennlist.com/forums/showthre...nterior+lights
Now after reading these threads it appeared that I may just have a bad door relay BUT it was stated that the windows should not go up and down once the door has been opened. My windows work constantly and also my radio. Any thoughts???
Thanks and have a great week.
Originally Posted by ittia
Hopefully just that for the int. lights issue but I think the rabbit hole goes deeper.
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Originally Posted by Droops83
The answer to your question lies in the threads that you searched for and posted . . . it sounds like the door contact switch. I noticed that a guy called MHT chimed in on each of the 3 threads and was right: the window relay will stay activated after you take the key out of the ignition until it sees a signal from the door contact switch, ie when you open the door. This allows you to roll up the windows after you take the key out and before you open the door, and the radio is on this circuit as well. I have seen this issue on many 944s and 964s, it will also cause the battery to go dead after a couple days since the relay constantly activated is about a 250 mA draw. Do yourself a favor and get new door switches, they aren't too expensive and will save your battery.
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Have a great day everyone.
Originally Posted by SchnellerUmsetzer
I have had the same issue with 3 of 5 944/951's that I owned. I took the screw out that held the switch in, cleaned the electrodes, re-installed the switch, and it worked fine!
Thanks for the hint
