Damaged blocks? Second run of Mahle pistons
Old 11-25-2006 | 09:43 AM
Ski's Avatar
Ski
Default Damaged blocks? Second run of Mahle pistons
JAB Racing doing second run of Mahle pistons - 100.5 and 101mm.
Ferroprint iron coating, slipper skirt design, new rings, and wrist pins. Compression 8.0:1, recommended cylinder wall clearance .020mm, ex: pistons are 100.460 OD, .020 clearance(x2) = 100.5 bore.
Price is $1100 + ship, $825 required at time of order(3/4), full payment with order gets free shipping. I will ship world wide but customers pay all customs and insurance. Pistons will come in their own box, bubble wrapped and should be within a .10 gram of each other, as the first sets were.
Placement of order projected for third week of December, pistons ready 8 weeks later. First order, great success, JME gave great report on the pistons.
email me your order request at blpski@yahoo.com
Old 11-25-2006 | 09:49 AM
JET951's Avatar
JET951
i needed a set of 100.5 about 5 weeks ago, but the price from factory was too expensive, so i ended up ordering the MID sleeves and pistons from Chris White. its always the way isnt it. your price seems very reasonable.
Old 11-25-2006 | 08:50 PM
Zero10's Avatar
Zero10
You make me angry
I bought an aftermarket set last year, and of course this year these come around.
20 years after they started making the cars..... why not make them in the 19th year when I needed them?
Seriously though, those look very nice. Will there be any more stock later, or the possibility of another run in the future?
Old 11-25-2006 | 09:33 PM
Ski's Avatar
Ski
sorry about that. Another run, maybe, I just had some people email me about them who are about to start the process of rebuilds and didn't feel comfortable with other piston options, even though the 4 sets of Tom C pistons that we've installed are all doing great, including our track car, so JAB Racing is doing another run. There will be a few sets left over when the order comes in; we're doing a 50/50 split in size on this order, the last one was all 100.5mm.
Old 11-26-2006 | 01:25 AM
Zero10's Avatar
Zero10
I no longer feel comfortable with aftermarket pistons after my experiences.. I wish these had been available when I did my engine work. None the less, they look excellent and they are priced very well. I am certain that they will make all of their new owners very happy.
I was just kidding with the angry part though
Old 11-26-2006 | 01:58 AM
JET951's Avatar
JET951
Zero10, do you realize that any piston is available from mahle. we have a mahle manifacturing plant here in australia. anything you want they will make. what aftermarket pistons did you use?
Old 11-26-2006 | 03:27 AM
Zero10's Avatar
Zero10
The Tom C pistons mentioned above. I'll save this thread from turning into an argument, but it would appear that I had a failure of the skirt coating on one piston, and that piston is eating itself away on the bore.
However, on last inspection there is no longer any piston material on the block and the piston no longer seems to be shrinking, but there is a very appreciable portion of the piston missing.
This may be related to the switch to synthetic oil from conventional, it is hard to tell.
Basically I built the engine, bored to 101mm since the cylinder walls were in bad shape. It burned oil like CRAZY for 5000 miles or so until I figured out that one set of rings was upside-down and flipped them over. While the engine was apart I found that roughly 1/8" of one side of the piston skirt on one piston was missing, and there was a large smeary aluminum streak on the cylinder wall that exactly matched it. After this work I switched to synthetic oil (since I was no longer consuming 20-25L/week of oil, I could afford to switch, yeah that's right, 20-25L) and the engine was broken in, however a very large oil leak appeared shortly after. I removed the engine to repair the oil leak (loctite failed on lower balance shaft cover) and to repair a bad TO bearing at approximately the 7000 mile mark, and while it was out I pulled the oil pan, since the gasket seemed to be leaking (turns out it wasn't) and inspected the bore. There were no longer any traces of excess aluminum on the cylinder wall, but the piston did not grow back.
I investigated factory replacement pistons and there were no other options available at the time. I posted on here lots about it before going through with this plan, probably 5 different threads about it. If I had known that I could get new pistons from Mahle I never would have investigated any other options. Also in retrospect since I went with aftermarket pistons I should have done MID sleeves and gone to 106mm.
Old 11-26-2006 | 11:41 AM
RajDatta's Avatar
RajDatta
Hi Skip, how about having them do a run of 104mm pistons .
Raj
Old 11-26-2006 | 11:46 AM
Ski's Avatar
Ski
the problem with 104 and 104.5 right now are rings that are unavailable, well unless you want to get Deeves or someone to make a minimum of 750 sets.
Old 11-27-2006 | 07:55 PM
951and944S's Avatar
951and944S
Bump for the pistons thread.
Oh....and erm, just for the heck of it Bret, you wouldn't happen to know what the outcome of the Tigers/Hogs game was would you....?
TS
Old 11-27-2006 | 10:02 PM
Ski's Avatar
Ski
yep, lost a battle but won the WEST war. Now, can the A-hogs show up for the Gators?
Old 11-27-2006 | 10:17 PM
951and944S's Avatar
951and944S
Heh heh, it was pretty much just the "battle" that I was wondering about....
T
Old 11-28-2006 | 01:31 PM
cpt_koolbeenz's Avatar
cpt_koolbeenz
Bret has some good connections... You can count on the stuff he is representing!
My Tom C pistons are still running strong... (knock on wood!)
Old 11-29-2006 | 09:01 PM
Ski's Avatar
Ski
The Tom C pistons are great. We've run them with his coating and had a set done with PC9 and Gold thermal coat from Swain. No worry Chris, the track car is running strong and still has 146-148# of compression with less than 2% leakdown.
got everyones email, orders will close on Dec 1st - had to speed it up due to Sebring race next year for a couple of people.
Old 11-30-2006 | 11:02 AM
Ski's Avatar
Ski
ok as it stands
JME.............2 sets 100.5
David M.......2 sets, 1 of ea
Ben.............1 @ 100.5
Andrew.......1 @ 101
Larry J.........1 @ 101
Alex.............
jy................
JAB Racing...4 sets, 2 @ 101, 2 @ 100.5
There are a couple of people taking engines apart this weekend and next week. Just let me know as soon as you pass the "fingernail" over the bores.
Quick Reply: Damaged blocks? Second run of Mahle pistons
