Spring length for Leda struts/coilovers
For those of you using Leda shocks on lowered track 944's (no torsion bars), what are you using for front & rear spring lengths and are you happy with the spring lengths your using ?
Originally Posted by shiners780
10 inch front, 8 inch rear. There is plenty of height adjustment capability both up and down with these lengths.
Originally Posted by eclou
My setup from Karl at Racers' Edge use 200mm all the way around IIRC. He would be an excellent source of technical info
I purchased 8" Hypercoils, 350lb Front, 475lb Rears. A lot of web searching and advice from Karl at Racers Edge & LEDA. Unfortunately not fitted yet so no idea what they will ride like.
regards
regards
