Bosch 044 noise Survey...
Old 10-19-2006, 02:13 AM
  #31
Driftomagnifico
Driftomagnifico's Avatar
Originally Posted by Tom M'Guinn
Yes, got 'em. Thanks.
Those are pretty neat.
I wonder if they have any UTexas ones.
Old 10-19-2006, 02:14 AM
  #32
Driftomagnifico
Originally Posted by KuHL 951
God-What an assinine statement
I'm not god, but I am assinine.
Old 10-19-2006, 02:22 AM
  #33
Andial951
Legend Killer
Andial951's Avatar
Tom,
Those are some DAM UGLY slippers.............BTW - GO BEARS!!!!!!!
Old 10-19-2006, 06:52 AM
  #34
special tool
special tool's Avatar
Originally Posted by Driftomagnifico
I can't hear my fuel pump over my gearbox, differential, exhaust, and wastegate. So as long as one of those is functioning I can't hear the damn thing.
Moral of the story is that if you complain about fuel pump noise then I hope you have tidy slippers to drag your old feet around with. Ones that are tall enough to keep your ***** off the cold pavement.
I don't know if he was complaining. I think he was wondering if that noise was expected of a larger fuel pump.
Old 10-19-2006, 09:16 PM
  #35
Driftomagnifico
Yeah probably.
I had been drinking prior to that post.
Old 10-20-2006, 01:46 AM
  #36
Tom M'Guinn
Tom M'Guinn's Avatar
So anyhow, I used a mechanics stethescope tonight and confirmed without doubt that the tap is residing in the hard fuel lines. I'll try isolating them from the body with split hose this weekend and report back. I know you are all on the edge of your seats on this one...
Old 10-20-2006, 01:48 AM
  #37
RolexNJ
RolexNJ's Avatar
Ok Dr. Very interesting, report back in after the prognosis.
Old 10-20-2006, 01:54 AM
  #38
KuHL 951
Hey Man
KuHL 951's Avatar
I hope I can sleep tonight I hope you find it, gotta love weird noises to drive ya crazy
Old 10-20-2006, 01:59 AM
  #39
RolexNJ
RolexNJ's Avatar
And change your avatar so it shows the blue car too!
Old 10-20-2006, 02:09 AM
  #40
KuHL 951
Hey Man
KuHL 951's Avatar
No avatar until it runs again...I can't push it to the photo shoot
Old 10-20-2006, 06:15 AM
  #41
Duke
Duke's Avatar
IIRC Ski's fix was to add a short bit of regular rubber hose between the braided fuel lines return line?
Old 10-21-2006, 04:02 PM
  #42
Tom M'Guinn
Well, I just spent the last 2 hours trying to isolate and eliminate the noise, to no avail. I put rubber around the fuel lines wherever they touched the body or the hydraulic lines -- from fuel rail to tank. No help at all. #$%*&^%$#!!!
Old 10-21-2006, 08:19 PM
  #43
Tom M'Guinn
Ok, I've eliminated about 95% of the noise -- probably good enough, you have to try to hear it now. It seems the noise does not come in through any one spot, but is more of a cumulative effect. The body pan seems to act like an amplifier of the pulsing in the lines. So, I got some sound deadening material at pepboys -- kind of a foil-backed tar paper -- and lined the length of the pan above the fuel lines. I also found that the fuel lines were tranferring the tapping action to the hydraulic lines, and that the rear hydrualic distributor (which is bolted metal to metal to the pan) was transferring a lot of sound . I put sound deadner under that as well. So, tomorrow I'll button it back up (may double up on the sound material first), and call it "fixed".
Edit, with the hood shut, it's virtually all gone.
Old 10-22-2006, 01:46 AM
  #44
chilibluepepper
chilibluepepper's Avatar
Tom - I'm glad to hear you chased down that noise gremlin. If the same thing happens when I fire mine up, now I know how to attack it. Thanks for your efforts!
Old 10-25-2006, 12:17 AM
  #45
RolexNJ
RolexNJ's Avatar
Alex & Tom, You guys have both helped me, and I think a lot of people too. Thank you for all the information. I am taking very good notes too!
Quick Reply: Bosch 044 noise Survey...
