Strut insert vs. strut assembly
Old 10-17-2006, 02:50 PM
kasturbo
kasturbo's Avatar
I've sold two sets now in similar condition. Someone will buy them.
Old 10-17-2006, 02:58 PM
Mercedesben
Mercedesben's Avatar
I am in the same situation as I have the inserts, but I cannot leave the car on the lift in order to wait to have the shocks rebuilt. The car is not by any means a daily driver I just cannot get it home from the shop to my garage. I need a donor pair of shocks to convert and then I can send my orig shocks back to the donor supplier. My shocks now are not the koni's but I need to haved someone install the inserts as my tech is afraid to do the conversion, he is a bolt on guy.
Old 10-17-2006, 03:13 PM
Rip It
Rip It's Avatar
don't forget that u have to have the front end aligned also
Old 10-17-2006, 03:30 PM
dr pepper
dr pepper's Avatar
I have a pair of front strut mounts, struts and springs from a 1987 951 for sale for $125
They have 63k miles on them. They are still connected to the mounts so it would make an easy install. I can sends pics by email...
PS - I am a member
Old 10-17-2006, 04:22 PM
Mercedesben
We have an allignment machine, so that would not be a problem. I have been given some track allignment specs so I can get that done.
I was hoping to find someone who had a set of 87-88 front shocks sitting around so I could "borrow" have them modified and then install them and give my stock shocks back.
Old 10-17-2006, 04:29 PM
jean_noir
jean_noir's Avatar
I have exactly what you need - I have the strut housing - pre-cut with the hole drilled in the bottome for mountint the new insert. I was planning on going that route but came across a deal for the entire stut/insert/coil assembly. I will post pixs if you like - they are from an 68 turbo but I think they all fit the same.
Old 10-17-2006, 04:42 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
Yes please!
toddk911
toddk911's Avatar
PS - I am a member
So the old ones I have would just be pulled, and these installed with no issues?
Old 10-17-2006, 04:45 PM
Mercedesben
is the 86 assy is the same ?
I did not think it was the same however.
anyone??
jean_noir
jean_noir's Avatar
Pictures -All you would have to do iis place that rubber seal around the edges, insert the "inserts" - and screw from the botto. Like I said they are from an 86 turbo. The are in great shape - minor surface rust - can be easily sanded off. $30 plus shipping (approx $45 in total) - they are just sitting by my desk collecting dust.
Old 10-17-2006, 04:46 PM
toddk911
toddk911's Avatar
Anyone know for sure if they would fit 1987?
Old 10-17-2006, 04:48 PM
Mercedesben
Todd since this is your thread you have first dibbs on shocks, but I am second in line.
Old 10-17-2006, 05:01 PM
jean_noir
jean_noir's Avatar
todd the only diff I see is the plastic cable holder and the brake cabl holder is at a different anglt - can anyone chime in here? pict shows 68 vs 89 turbo
check your inbox for paypal info if interested
Old 10-17-2006, 05:03 PM
jean_noir
jean_noir's Avatar
gotta go - ba ck soon - todd text me if you want them.
Old 10-17-2006, 05:27 PM
toddk911
toddk911's Avatar
Jean: Ok, I got your PM and replied.
Well, looks ok.
Anyone else know if 86 would be an issue?
Merc: If this works out, since I am getting help on this, I would be willing to sell you my old Koni struts for you to work on real cheap. Or at least for what you would be able to sell your stock stuts for.
Quick Reply: Strut insert vs. strut assembly
