catch can
#32
Originally Posted by reno808
thanks rolex
#36
Doug, a proper catch can will have internal baffles to catch the oil. On your car, you must route the catch can back into the J-pipe. The factory crankcase requires a vacuum.. No vacuum, you get excessive crankcase pressure, your turbo will not drain properly, eventually it'll flood and your engine will smoke.
If you have enough blowby to need or if you fill the catchcan, something is wrong with your engine.
#37
john,
what i am having is oil coming out the exhaust under heavy boost...do you think this could be from blowby or like you said somthing wrong with the engine?
#38
Originally Posted by dougoh
john,
#39
Do you have a catchcan on or a breather tank? Also if you do is it routed back into the intake system rught before the turbo? Cause if its not like john said it will flood your turbo and spew oil into the exhaust system..
#41
Doug,
What do you mean you get "oil" do you mean blue smoke or actual oil?
Any time a turbo engine has oil problem, you have to narrow it down to few areas (not in any order):
- Head (bad guides, bad seals smoke at startup). Problem on the exh. side is a pain to chase down.
- Rings and/or cylinder walls. Leakdown test is a good start, but this will not show a bad oil scraper.
- Turbo - bad unit and/or not draining properly.
Once yu figure out which are is causing the problem, you can dig in deeper.
- Do you have any oil in the intercooler?
- Any smoke under high engine vacuum
You want to hone in on the symptoms, it will make it easier to locate the cause of the problem.
#42
okay john i will do some investigating ...thanks for giving me some things to get started with...just to let you know the head was freshened up when i put the motor in...oh and from what i saw on my brothers 993 winshield as he was trying to keep up with me at the track...it was oil coming from the exhaust
Originally Posted by fast951
Doug,
#44
Hey Man
Call me Po' Boy Racing but I went the Home Depot catch can route. Bought a $10 Campbell-Hausfield water/oil separator (MP5138) for an air compressor. It has a small 6-oz clear bowl, O-ring, and a Shreader valve with cap to drain it. I bought two air hose couplings that matched the hose ID. I had an issue with blowby and oil in my throttle body and ICV on the BMW. So far it has collected a couple ounces of moisture and oil in 3 weeks of daily driving. Take a paper towel, push the valve and it all drains out. The entire intake is now drier than a Texas popcorn fart. Less than $15 bucks but it does lack the bling of all that shiny looking stuff.
Page 4: http://www.campbellhausfeld.net/wcss...ccessories.pdf
