Group Buy 4 Dynatech-Strut Bars & Camber Plates-Get 'em while you can
#181
Oh yeah, I've recieved mine. It looks great! If only my engine bay wasn't so dirty... I'll take some pics of it installed when I take the car apart for some other work in a week or so.
#182
Originally Posted by SoloRacer
No I don't but you can see the intercooler piping on the exhaust side of the engine which takes you to where the turbo sits. To get a picture of the turbo system I would have to get the car up in the air. The turbo is mounted low on the passenger side and sort of hangs off the headers. The wastgate is a large 930 model and tucks up under the drivers side. The exhaust is all custom stainless and uses some pretty nice v-band clamps. There is an oil resevoir and weaver pump that pumps the oil back to the oil pan after it goes through the turbo. This is done because the turbo oil drain sits lower than the oil pan.
#183
This was on Nov 18th
Ed: The spring perches are now re-stamped. I've got to get them cleaned up and re-painted, which I'm hoping to do tomorrow.
I got mine and eveything looks in order Thanks Ed
thingo: waiting for bar bending and bracket polishing. Will ship sometime next week.
Sean
He still hasn't got anything.......
Any word Guys ( Sean or Scott )
I feel like we left the poor guy, hung out to dry .....
Regards
Ed
Sean
Regards
Ed
#184
Eddie,
Sorry I've been out of pocket, it's been a real ordeal the last few weeks. First, my water heater crapped out and I lost hot water. As soon as I got that taken care of, my hard drive crashed. Got a new drive installed and I'm trying to get everything re-loaded.
I haven't been able to get onto the DHL website for the Australia orders. I should have that sorted out in a day or two.
One of the things I lost in the hard drive crash was the updated copy of the order status, so it will take me a little time to re-check the camberplate waiting list. If I'm not mistaken, Eddie you are the first substitute for a 968 STB, but let me double check this.
I should have everything back on track in a day or two.
Thanks,
Sean
Dynatech
Thanks,
Sean
Dynatech
#185
Here's the camberplate order list:
We've got 3 pairs of camberplates in stock right now, and 3 more at the machine shop, based on what my machinist says, that I still have to pick up (and anodize and electroplate).
Soloracer: You're up first. However, as this is going on a 968, you will need the button head capscrews on top for hood clearance. The current batch of camberplates in stock use a standard socket head capscrew with a taller head and a longer thread. Best thing for you would be to get a pair out of the last batch. Can you wait a few more weeks? The button head capscrews look really nice. It's a torx drive button head and we will include a torx bit.
facboy: Are you still around? I still own you a DHL price. I should be able to get logged on in a day or two. You're up second.
blodstrupmoen: Got a set here for you. I haven't checked my PM's and it's really, really late here. Have you sent the spring info?
Rob Fair: You are first up on the last batch or alternate to soloracer for the 3 sets in stock.
MitchB: Got both of you down for the last batch.
Eddie: That should leave one pair from the last batch unless someone drops out.
See ya,
Sean
See ya,
Sean
#186
See ya,
Sean
Yes sir,
I have koni shocks and hypercoil 2,5" springs .
#189
See ya,
Sean
See ya,
Sean
I'm in no hurry. Put me down for a set from the last batch. I've got some fitment things to resolve with the 968 Bar first anyway. I think I have to change to a lower profile motor mount. The bar is resting on the top of the vanity cover currently. However, I think when they did the turbo conversion they may have lifted the engine some since the vanity cover was rubbing on the hood for some time.
Erik
#190
Eddie,
Thanks,
Sean
Dynatech
Thanks,
Sean
Dynatech
Yea... I would like the 968 SB
Please do whatever you can to get Rod ( Dingo ) his stuff
He really has been more than patience ...
Please
Let me know when you want the money for the 968 brace
Regards
Ed
#192
Sean
Any word on the 968 SB ?
regards
Ed
regards
Ed
#195
Erik (SoloRacer):
Just catching up on the thread. Sorry I was busy with the holidays. I'm sure that we can resolve the clearance problem with the 968 strut brace. The first option is to add some additional bend to the bar. If there is sufficient clearnance between the hood and the bar, then this is the route to go, which we will do at no charge. If your car has abnormally tight clearance for some reason, we can mill a relief slot on the underside of the bar over the fuel rail cover to give additional clearance. You will need to check the hood clearance, per the installation instructions. If you do not have the 968 instructions, then PM me with your e-mail address and I will send them to you.
We will get this problem fixed for you one way or another.
Sean
Dynatech Motorsports
Sean
