Oxygen Sensor w/ Hesitation
have the same type of thing with grounds. Where do I check those? Thanks
Hi,
Start from those cables & later on you can add an additional ground from chassis to engine block.
https://rennlist.com/forums/showthre...ghlight=Ground
Hi,
Originally Posted by black944 turbo
Schnell what do you mean by reseting the CO2? Idle is set properly, the AFM is set properly, and the TPS is ok.
Thanks, Richard
Thanks, Richard
To set the Idle correctly you need P9246 pluged in and turned on or jumper cables that accomplish the same thing. This, installed in to negates the ISV. The motor has to be warm will all fans off (AC and cooling).
This according to www.clarks-garage.com
idle is 840RPM +/-40
Thanks, my CO2 was adjusted when I bought my car from the local Porsche specialist because I failed emissions. So that should be fine. Also, I had the intake off recently and did not see any signs of corrosion, I will check it again. I appreciate the info.
