Engine Locked Up - Place Your Bets!
Well, tried to start my car again today after fixing a few things on the MegaSquirt. She cranked fine, almost caught a few times, then after a few more attempts locked up solid.
Pulled plugs, starter, and depressed the clutch pedal... Cant spin it by hand with a long pipe. Timing belt looks fine and seems tight. Its brand new, no missing teeth. Oil pressure pegged the gauge was at max on the stick. Car had coolant in it.
So place your bets... Broken ring? Broken rod? Broken rod bolt? Valve contact?
I was so close
Now.... Where is that engine hoist and my case of beer.
I was so close
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Originally Posted by special tool
Dude - what did you do??? ![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Shes been cranking over fine for the last few days as I chased down niggling issues. Oil pressure seemed perfect the whole time. Tried to start today, almost caught a few times then it locked. Had spark, had fuel, all seemed fine. Rod bearings were replaced as was the crank.
I think im cursed
I going to go loosen off the timing belt and see if that gives any clues...
Did you hear ANY noises of any kind? Just take the t belt off, mark the cam gear and cover for orientation, and see if the cam is free +/- on either side where it is now, at least to see if that's free.
Loosened the TBelt, cam can move to either side so I guess its definatly the bottom end...
That's some really horrible news, try to keep your cool man. Maybe the timing belt skipped enough teeth for the valves to make contact?? Good luck diagnosing the problem.
Originally Posted by MPD47
Do you smell fuel? Fuel pump still on? Not the most likely situation, but I've seen it happen before when there was an issue with an injector and EMS.
Draining the oil now to see if I can see any metal.
Well cam tower is off. All the valves are there and seem to be lined up, so no bent valves... Still cant spin the engine in either direction so I guess the engine is coming out tomorrow...
before you pull the engine, I have one suggestion: loosen the bolts on the bell housing enough to back the housing off by 1/4 - 3/8 of an inch, then try to turn the engine over to see if it's free - if something went wrong in there and anything is hitting the bell housing, it won't turn either.
We had to loosen the bell housing when putting in a new clutch on Rhobs car, 930 disc with Cup PP. got it stabbed and the damn engine wouldn't move. We backed it off about 1/4", engine and flywheel were free, got all the PP bolts in, snugged it up, all good, then tightened the bell housing back up - that was 2500 miles ago.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by theedge
Thanks for the suggestion, ill give that a try. If worse comes to worse, Chris White might be getting some money from me this winter ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
The engine won't budge in either direction?
Campeck Rulez
I started shivering when i read that.
Find what went wrong yet?
edit- i saw "yesterday" as the last post and thought..oo. maybe he found out already..but..since its 12:19...11:00 oclock would have been yesterday. my bad.
