Went back to the dyno today....
Old 08-31-2006, 01:11 PM
  #121
MPD47
The Carnage King
MPD47's Avatar
Originally Posted by A.Wayne
Mike the alpina M30 , biturbo engine was placed in this e30 , very stout engine and the 535 i engine has the strongest bottom end of all the stock bmw engines.. of course the 4 v engines of the M cars is the way to go . as the heads flow very well, even better than than the current M engined cars .
ST , would be better off starting with a 4 V engine , to meet his power expectations.. but spend enough , anything can be made to fly...
Yep, that car was on ebay just a short while ago too. Long discussion about the one on ebay being quite suspect due to photos and the supposed "owner". We're working on an M30 right now that should do 400-600 depending on fuel
Meanwhile my S38 sits dorment until the 951 is done and I feel the urge to work on it.
Old 08-31-2006, 03:40 PM
  #122
special tool
special tool's Avatar
You have an S38??? I know a guy looking for one.
Old 08-31-2006, 04:57 PM
  #123
MPD47
The Carnage King
MPD47's Avatar
Not for sale, sorry
Old 11-01-2006, 04:33 PM
  #124
special tool
Still working diligently on that 600 wheel......,
oiling troubles.....will keep you guys posted.........
Old 11-01-2006, 04:48 PM
  #125
RolexNJ
RolexNJ's Avatar
Default Issues?
Dude, I don't want to hear about issues of any sort, get it sorted out and put up or shut up. So that's all you have to report, oil issues? Fix it and get your butt back there. Have many days are left until the end of the year? Your clock is ticking pal, you better break 600 RWHP!
Old 11-01-2006, 05:00 PM
  #126
Ian Carr
That Guy
Ian Carr's Avatar
Rob do you work? LOL your always on here hahah.
Jim im getting that turbo, and header tomarrow. Ill be home the week of thanksgiving, can we wrap the turbo and header then? lmk
I-dogg
Old 11-01-2006, 05:03 PM
  #127
Duke
Duke's Avatar
What are being changed since the last dyno run?
Old 11-01-2006, 05:31 PM
  #128
Ian Carr
That Guy
Ian Carr's Avatar
i believe he is going to be running a different turbo along with some other special tools
Old 11-01-2006, 05:52 PM
  #129
RolexNJ
RolexNJ's Avatar
He is adding that Popeye Spinach turbo and some other mystical parts he got from the Land of Oz. And Duke, you changed your avatar to a "Gay Bar" one? Have you switched sides, or, you just like being how Lart is?
Ian: You don't get it by now? The second the Tool is on here, he pages me so I can follow him and worship the RWHP King
Old 11-01-2006, 06:00 PM
  #130
special tool
I-dogg
Yes, that stuff is like a round of golf to me (if I was a froot-loop and played golf)
Let me know when you want to do it.
Duke - Turbox is correct about the mods.
The oil problem basically stems around the factory AOS.
The amout of vacuum in front of a turboharger making 750 HP, is literally sucking the oil out of the AOS.......
I'll get it sorted out.
Old 11-01-2006, 06:04 PM
  #131
kasturbo
kasturbo's Avatar
How do you know this? What signs does this problem give?
Old 11-01-2006, 06:11 PM
  #132
special tool
Process of ellimination.
Everything on my engine is new. I have EXACTLY 130 static compression in all 4 cylinders (this with fairly radical cam), tan plugs, tightly controlled AFR and timing and most of all, the oil pickup is proportionally more than my last configuration in accordance with the cfm increase.
Old 11-01-2006, 06:18 PM
  #133
kasturbo
kasturbo's Avatar
What are the symptoms that make you think something is wrong is what I should have asked. Sorry. Increased blow by, low/high oil pressure? Are you still plumbing the aos back into the intake? Do the symptoms increase if you vent it?
Old 11-01-2006, 06:20 PM
  #134
special tool
Oh - I have a catch-can that I set up for easy monitoring.
Old 11-01-2006, 06:22 PM
  #135
kasturbo
kasturbo's Avatar
Gottcha.
Quick Reply: Went back to the dyno today....
