Make your own SS Fuel Lines
#32
Post number 6 on page one.
#35
Looking at the stuff BAT sells why even use compression fittings. They have everything you need to run steel braided all the way from the filter to the engine for little actual cost. Just get a metric - AN adapter on each end and your set.
#36
That is definitely an option. One consideration is the cost between a pair of compression fittings and many more feet of SS line. And the installation would be a bit more involved...
#37
I used Goodridge AN Fittings (http://www.goodridge.net/usa/index.htm) and braided SST tubing to fabricate my hoses. Call Mike Lang: (317) 244-1000 to order.
They are very high quality and easy to assemble with a little patience. They have been in use for a couple of years now with NO issues.
Saved quite a bit over buying them through a fabricator and you don't need any special tools to build them up.
Good luck!
Good luck!
