isv not working, electrical
man i dont want to do this again,just replaced the isv because i figured it was old and not working, since i had to keep my foot on the gas while cold, the a\c on, and when the fans kicked in.
so i replaced it today with a new one, still the same as before didnt fix anything so im guessing its not getting power is there a fuse for it or what? do i need a new cable it looked pretty gummed up.
jumping the test connecter does nothing
its hot out in the garage too(las vegas) now what the tps is adjusted correctly
i resealed the throttle body about a month ago and thats when it started to idle real low, i get about 16+ in hg at idle and about 25 on decel if that matters
any help appretiated
UAE Rennlist Ambassador
Did you try setting the idle using the diagnostic port?
http://www.clarks-garage.com/shop-manual/fuel-08.htm
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/282192-confirmation-on-isv-power-to-the-conectors.html
That has the testing procedure that I posted about 2 weeks ago...
