Anyone happen to have an '89 Turbo Transmission?
Cows-4-Rent
This is for the 944....I lost my third gear and am debating between rebuilding and replacing. Replacing is the short term fix that will get me to another race this year but either way, I will rebuild my current box. Never hurts to have a spare.
Thanks in advance.
Jeff
Thanks in advance.
Jeff
Basic Sponsor
Thanks in advance.
Jeff
Thanks in advance.
Jeff
I have a 87" 951 and a 86" 951 trannies both non lsd and a 86" 951 lsd.
Cows-4-Rent
1st and 2nd gears are thicker on the S's and '89's so you can't retrofit the box. In addtion to the LSD, they also have the external oil coolers
Basic Sponsor
all of my trannies have external oil cooler, I am running a 86 with limited slip and my car has 341rwhp and 349rwtq and the tranny holds just fine.
Basic Sponsor
Here is the ebay link to the 86 turbo lsd tranny that I have for sale.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEUS%3AIT
I have a MY89 951S tranny ($2.8k) , a MY87 LSD no cooler ($1.8K), and a 968 6-spd with a new GT3 factory LSD recently intalled ($4.8K). 2 out of the 3 will be up for sale, All is great conditon. Shipping & Packaging extra...
The TS input shaft has the additional hardening performed on the 1st and 2nd gear teeth, but are dimensionally identical to the earlier Turbo input shafts. Since even high hp/modified early Turbos do not have a tendancy of busting up 1st or 2nd gear, Im not positive that the harder teeth on the input shaft are really that critical.
The Turbo S LSD units have thicker inner friction discs and so the pressure rings are different - they both have to be replaced together when/if rebuilding an earlier LSD unit. Again, may be nice, but not critical - even for a track car.
So if you find a nice 86-88 Trans with LSD and cooler options, I would definitely consider buying/using it in place of an original AOR trans (since the differences are probably not worth the extra $ premium for a "Turbo S" trans).
ALL model year 951 trannys had the LSD and/or Oil cooler loop as an option. (not just the TurboS's)
I would rather own a low mileage & undamaged 86 951 gearbox w/ LSD with or without oil cooler, than a highmileage 951S gearbox with LSD and oil cooler. (which is what I have on my car now.)
