How much HP can K26/6 max out?
Small Business Partner
Hmm, I thought the K26 was rated @ 35lbs/min...nearly 500cfm.
Using an the 10hp for every lbs that gives a lot closer to 350crank hp.
Rogue
Rogue
I would guess even if you ran upto 20psi with the stock turbo and mostly stock parts, you could still only get to the 260rwhp range, the TQ would be impressive but power would drop off like a rock! I know most with the k26/6 turbo (like mine) usually hit the 240-260rwhp with running mostly stock parts (no internal engine mods, just like injectors, maf, testpipe, boost controller, chips, etc). I know before I did my MAF and piggyback I hit 240's rwhp and 290's rwtq, since my maf upgrade I would guess another 10 rwhp but not much else and that is running 15psi.
Rogue
Rogue
You would need extreme efficiency to get that out.
Chris, the head mechanic at Technical Dimensions in Jacksonville has the cleanest 951 I've ever seen. Stock K26/6 that is very close to 300rwhp, but he has a lot of time and money into his car(and engine) and is tuned to perfection. I think 250-260rwhp is what most people can get out of a K26/6.
UAE Rennlist Ambassador
300whp is possible, but at 20psi+ the K26/6 would be pushing it.
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/179187-301rwhp-sae-corrected-k26-6-yeah-baby-video-up.html
