Is the k26/8 much better than the k26/6
Old 07-01-2006, 12:25 PM
KuHL 951
Hey Man
KuHL 951's Avatar
From a previous thread:
Comparing that to the previous picture it looks like the flat spot is on that K26/6. I've checked my K26/8 and it has the correct ...03 ending part number on the blue plate as well as no flat spot.
Old 07-01-2006, 12:51 PM
special tool
special tool's Avatar
Originally Posted by JDeitz951
With all due respect; No, no, no. I just replaced my K26/6 with a K26/8 and sitting on the bench side by side, the no. 8 hotside is visibly larger. Too bad I didn't have the camera that day. The outside of turbine housing on a 6 is spprox 1.5" wide while the 8 is approx 1.75". I have micrometer eyes so you know I'm right (30 years in designing and building machines does that).
Okay, I didn't mic it.
The IMPORTANT difference is inside the housing.
Old 07-01-2006, 01:07 PM
Pauerman
Pauerman's Avatar
I've found the same results as ST. I've got a KKK #6, KKK #8, #8 replica Stg 2, #8 replica Stg 3, #8 replica Stg 5, and #10 Stg 5. The O.D. and width of the turbine housings are the same - kkk vs kkk and replica vs replica. It's the shape and depth of the cut inside the castings that differ.
Old 07-01-2006, 01:36 PM
Laust Pedersen
Laust Pedersen's Avatar
For those also interested in a dimensional comparison see my post #4 here .
Having had both in the same car, I have to say that the K26-8 feels like a more “natural” match. It does come on at a higher rpm (about 3200 vs. 2800 rpm), but does it more gradually. It also holds the boost easier to red-line. The K26-6 can hold good boost to red-line too, but since its back pressure is seriously pushing on the WG valve, some clever WG control is needed.
Btw, a -6 turbine cannot be machined to a -8 turbine. The widths of the scrolls are different.
Laust
Old 07-01-2006, 01:55 PM
eclou
eclou's Avatar
Received 1,195 Likes on 584 Posts
Laust
Laust, could you expound on this statement? I would be very interested in what this clever WG control consists of
Old 07-01-2006, 02:09 PM
Mercedesben
Mercedesben's Avatar
Scott, on my last 951 (yours now) I took the lsd for granted on the track, I did not realize how good it was, it sounds like the s2 unit is better with the gearing as well. Maybe I should just put in the s2 lsd tranny and call it a day. I just got my 275 width r compounds for my rear 10" fikse wheels, I hope the rubber tames the wheelspin somewhat. If I increase the HP I will just increase wheelspin. What good is HP without traction!!!
Ben
Old 07-01-2006, 03:10 PM
Laust Pedersen
OK then, my trick WG. Since I don’t plan to sell modified WG’s (except if someone really wants it) then here is the basic idea:
Utilize the backpressure to counteract its push on the WG valve, by using the gas seepage between the valve stem and guide to the chamber below the diaphragm above the main housing. The chamber below the diaphragm is vented with 4 small holes, but some gas also escapes at the mating surface.
To make the boost pressure (close to) constant, seal the mating face, tap the four holes and plug them with screws. Drill a hole in one of the screws and adjust the hole-size to balance the resulting forces on the diaphragm and the valve head. Too small a hole and you’ll have increasing boost pressure and too large a hole and you’ll have decreasing boost pressure.
To make higher boost pressure possible I also added an extra spring.
In short: the gas force equalization tilts the boost curve (counterclockwise) and the extra spring translates it (upward).
It has actually worked for me for a year now.
Laust
Old 07-01-2006, 09:54 PM
LFA951
LFA951's Avatar
Actually, one inch equals 2.54 cm, so the 6 is 2.36" and the 8 is 3.14"
Old 07-02-2006, 03:46 AM
SchnellerUmsetzer
SchnellerUmsetzer's Avatar
Big question:
DID ALL 1988 & 1989 951's come stock with the K 26/ #8? I was told that they did!
Old 07-02-2006, 03:53 AM
Rich Sandor
Rich Sandor's Avatar
^^ All 88S and 89, 90, and 91 turbo's had a k26/8.
All 86,87, and 88non-s turbos had a k26/6.
Old 07-02-2006, 03:59 AM
SchnellerUmsetzer
I have been talking with a guy with a K 26 out of a 1988. If it is a #8 I will buy it.
I thought all 1988 and 1989 were S.
Old 07-02-2006, 04:01 AM
Rich Sandor
No, in 1988 there was both an regular 951 and a 951S.
Old 07-02-2006, 04:17 AM
SchnellerUmsetzer
Yes,
After reading a bit more in "Clarks-Garage" I came to the same conclusion!
Old 07-02-2006, 09:27 AM
JDeitz951
Lifetime Member
JDeitz951's Avatar
I was talking about the width of the housing in the axial direction (parallel to the shaft), not the radial direction (perpendicular to the shaft).
Old 07-02-2006, 09:29 AM
eclou
eclou's Avatar
Laust
This is on a stock WG? Do you have any pics or diagrams? I'd love to try the same on my Tial
Quick Reply: Is the k26/8 much better than the k26/6
