DFASTEST Vegas Experience
#46
Originally Posted by DFASTEST951
Al, the 3 liter is much has more torque down low and the transition from n/a power to turbo is a lot smoother. A lot less noticeable lag. I get max power at 5800 rpm.
Do you have a dyno sheet on your car. 5800 rpm max power on a 16v turbo is very low. With as much boost as you say you are running there is no way the engine will roll over even with a stock head and cams
#48
There was a plastic covering over the sheet. Sorry. You can see how the APE chips are way too rich in the mid range. Otherwise I'd be a straight shot up. I can manipulate the mid range with my foot to get better results now but I really need to upgrade a bit. Researching now...
