Could someone with a clean '89 951 check something for me?
Kevin, you have one heat shield missing, that goes between the upper balance shaft housing and oil supply/turbo downpip & hotside, or is you'res removed when that picture was taken?
It is silver as well, not Zinc plated.
CLR stripped the plating on everything including the small shield. I have the big one soaking now on a corner to see what it looks like.
Porsche used the zinc dichromate (some say cadmium) plating on some of the early cars, like my 87 which I am in the process of restoring now.
For some reason they changed 88-89 to what appears to be silver zinc plating.
I have a friend with an 89 and his brake shield looks exaclty like yours.
Good luck with the restoration.
To set things straight zinc plating is gray not yellow and is nothing more than electrostatically applied zinc rather than larger grained hot-dipped galvanizing. The old school cadmium and cad-zinc plating is yellow, the newer replacemnent zinc dichromate plating is yellow and the yellow part is a dye with no real corrosion protective qualities like the cadmium. The electostatic zinc is fine by itself but isn't as good as cadmium or hot-dipped. Clear as mud right?
AHHH- now we're getting somewhere! Thanks for the PM and picture Turbo Fanatic.
Murky water now, but better than mud. I'm pretty sure I asked the plating shop if they did yellow zinc plating, not zinc chromate or dichromate. I hated Chemistry for multiple semesters, and don't like to pronounce words ending in "ate" or "ide"..
I think I recall from searching that the cad and cad-zinc are getting phased out for safety reasons. Does anyone still do cad or hot-dipped anymore?
The guy I talked to at the plating shop did say that at least one of the dipping processes was pretty hot. I'll call tomorrow to clarify the types of plating they do.
One thing- be careful about what you strip. The metals you are removing are very nasty zinc, chrome, cadinum. These really need to be disposed of correctly. It's much easier to have a plating company strip and replate your parts. It will cost a few dollars extra, but they are set up to do it, and there's no need to add your personal residence to the superfund site list.
Kevin,
don't worry yellow zinc is the same as zinc dichromate.
Finding cadmium is getting tough these days because the EPA is making it difficult for platers who use it. They are even making tough for the zinc platers.
While it will not have the ultimate corrosion protection and cadmium,
zinc will do fine and is what is used in most restorations. Consider yourself lucky to find a local plater that does zinc rack plating in small runs. Outfits like Burbank plating only do barrel plating which won't work for heat shields and larger items. Ones that handle rack plating want to do large productions!
Chris- That HS goes under the exhaust manifold.
James- I called a ton of platers in Phoenix before I found one that would do it. Most told me that NOBODY does Cad anymore, and they didn't know anyone who did yellow Zinc. I was lucky- the place that that does it is right down the street.
Originally Posted by cpt_koolbeenz
Little OT,
But where does that HS go that is in the bottom center (just to the right of the down pipe) of David's pic? I have it sitting here, but don't remember where it goes!
I have a great plater, near by here, that did a great job on my parts. He does, both rack and barrel plating and did a awsome job on my stuff. I was amayzed how it came out
I did work my *** off on every nut, bolt, washer, bracket and heat shield etc.. All were abrasive wheeled, then polished, and then given to the plater. He is located in Mountain View, Ca. The company is 4 D Metal Finishing.
He was cheaper then most, and was very trust worthy. No affiliation
Cad plating is still avail, in places like Texas, but the color will not look nearly as nice or stock as the yellow chromate zinc. The general rule, from what I understand is, that the darker the plating the better the resistance to corrosion. ( mind you, this is for Electroplating, not Hot Dipped which is the very best protection ) So i.e. isliver yellow olive drab then black oxide..... would be from worst to best
Here is a shot of what I did last summer. Sadly, it's still in the boxes and I still have another round to go I am thinking I should have it all wrapped up by the next millennium
the first is Plated Yellow chromate the second is the Jet Hot
Regards
Ed
Regards
Ed
Regards
Ed
Regards
Ed
So Ed - What museum has offered you space to display your Silber Rosa timepiece? You aren't really going to drive it are you? So when is the launch date? JK - Those parts look great. Now when you go on runs you'll need the clear plexiglass hood so we can all oggle your fine work
