How do I clean exhaust valves?
I have a used head I am using to replace my head with the burnt valve (thanks Ski). The used head is currently disassembled and I would like to clean up the exhaust valves before reassembly. They have quite a build up of carbon - especially at the stem radius. Any ideas?
Thanks,
Thanks,
soak them in some cleaner, carb dip is not bad neither is motoroil, then brass brush the bigger chunks and when you get them pretty clean chuck them in your drill press or lathe and finish them off with some fine steel wool or scotchbrite try to stay away from the valve guide area as well as the valve seat. the porsche valves are pretty tough but i never take a chance on them not sealing. DO NOT media blast them with glass or sand, you will surely hate yourself in the morning. just make sure they are 100% clean before going back in.
I have always cleaned mine on a wire wheel on a bench grinder. If you are having the faces recut (which you should) then hitting them wont matter. As a previous poster stated, don't go up the valve stem to the part that runs in the guide .. leave that alone. You can also wire wheel the grooves for the collets.
A drill or a lathe...
Just don't go too crazy with the abrasive and put scratches in the metal, i.e. stress concentrations where a crack can start.
Carb cleaner takes most everything off but smells like $%*!.
Good luck!
Good luck!
Originally Posted by mark944turbo
I am pretty sure you can push a valve against a wire wheel for as long as you want, and it will never scratch. I have done this many times, never a problem.
