944 Parts FS
944 Parts FS
Hey guys,
I have a bunch of 944 parts (mostly 86 turbo from what we can tell) that buddy and I picked up in a barn find, so we want to get rid of most of it. I have not sorted a lot of it, but off the top of my head here is what is available. I know used 944 parts prices pretty well, make me a fair offer and I would rather deal that way then sitting here setting prices on things. It will be a first come first serve basis. I can post pictures as requested. Sorry the 2 turbo motors are mine for now
3 944 Brembo Turbo calipers. 2 lefts and a right.
2 Washer tanks in great white condition, with headlight washer motors (not tested).
2 washer pumps for the windshield
1 set of Yellow Koni Front struts and rear koni shocks. No springs or top hats. I would like to sell this as a complete set. There are a couple people in line for these, just waiting for some replies.
2 more sets of Yellow Koni front struts. One set has weltmeister 250lb springs on it, the other set has stock springs.
Intercooler air duct shield.
Pair of intercooler pipes
AFM
Driver's side mirror housing. No mirror assembly, but the motor is there. Champaine color as well.
Fuse box with fuses and relays (late)
Sway away Torsion Bars: Part numbers 1228 R 0594 and 1228 L 0594. I don't know if they have ever been used, and I believe they are 28mm, but I need to measure them.
Cruise control computer Part number 944.617.132.00
2 cruise control motors
Brown leather shift boot, with ****, and brown 5spd pattern insert. In pretty good condition, no rips or tears.
1 PS return line (metal line with the rubber hose end). In good condition
1 Pair of uncracked rear taillights.
4 aluminum control arms (one brand new), I may hold on to these though.
1 piece crossover pipe.
2 piece crossover pipe minus the curved 2nd piece....still have not located it yet if it is here.
1 set of headers, I need to look them over good. They still have the metal tin covering.
1 driver side porsche script outer door handle. The drop link piece that usually breaks, is well, broken, but the handle is fine. The drop link piece is cheap, I can get a price on it.
Idle Control Valve
2 sets of stock sway bars front and rear (with the main drop links for the front) (I will measure, but I believe the fronts are 26mm and the rears are well, whatever the stock 86 came with)
Turbo cooling pump
1 PS rack. The tie rods are pretty loose, but the rack appears to be in good shape.
1 radiator
AC adjusting rod
PS adjusting rod
4 turbo fuel injectors in good condition
Brown cargo cover...that actually appears to retract.
1 front spindle and hub, but I can't remember which side it is off the top of my head.
I might be talked into selling one of the turbo intake manifolds with throttle body.
There are brake dust shields, air duct shields, alternator air covers, and a bunch of miscellenous stuff. There is a freshly rebuilt K26/6, but I will probably hold on to that as well.
What I know isn't there for sure or are not for sale, which usually get asked about:
Engine's
Turbo's
Intercooler (well there is, but it is busted up pretty good)
Body panels, other than a sunroof
Wheels/Tires
Seats
Interior trims
Dash
coolant tank
AFM
Idle Control Valve
Turbo cooling pump
1 radiator
AC adjusting rod
PS adjusting rod
Engine's
Turbo's
Wheels/Tires
Seats
Interior trims
Dash
coolant tank
Basic Sponsor
1 Rear 944 Turbo valence. Color is champaine. Piece is in great condition, but could use some polishing etc as it has the usual scratches on the bottom.
How does 125 plus shipping sound? If you want a picture, I can email it. I'm trying to host as few pictures as possible as my server is getting pretty full.
Basic Sponsor
Basic Sponsor
Pesos were sent.
Originally Posted by Ski
got a pic of the Koni coil overs...which probably need to rebuilt?
I can dissasemble them no problem to check them out, but I will probably leave them disassembled but still include all the parts for the strut, ie springs, hats, etc.
Originally Posted by VWaddict
Any other electrical stuff? -Relays, cable etc?
Keith
Keith
Im interested in the full set of konis without the springs and the torsion bars, How much are you looking for? for each
you can pm me or email me at sprammer@gmail.com
thnaks alot,
Kell
thnaks alot,
Kell
Hey Karl, Chris was telling me about that car the other day. Is that going to work out as a track car? Oh, and I have an intercooler if you (or anyone else) needs it.
Regards,
Regards,
Regards,
Regards,
