Best antifreeze for the 951
As title states I was wondering if any are better for our engines than others as I am getting ready to filler up.
Thanks for any input.
Dex-Cool is what I use... It is phosphate free. Use distilled water though!
There have been long debates in the past on this subject... A search is likely to turn something up.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The Evans non-aqueous coolant is working fine so far. I wasn’t having heat problems before and I added a Griffen radiator so the tests are not really conclusive.
I do like the less pressure in the coolant system (only a couple of pounds at full temp).
The only down side is that the stuff is very slippery and due to the fact that it boils at 370 any coolant spilled on the block will NEVER evaporate – it just sits there and smell like hot coolant!
To get the full effect the entire system has to be drained. More than a couple of percent of water in the system will greatly reduce the effect.
Chris White
Chris White
