300rwhp, 12.9 1/4 ???
#61
Drive-by provocation guy
"but there is no test that gives you accurate results for so cheap."
I think the best measure of a cars performace with the least amout of stress on the car and taking the driver's abilities out of the equation is the 60-100mph, 3rd gear test.
#63
Wheelhopping is usually caused by too stiff shocks (for dragracing) but could be combination between many things (worn out bushings, shocks, rear suspension alignment etc).
#64
95ONE: You need to get with PorschhhJohn. I think he is in Houston. Done a lot with his car and is really into the turbo/import scene as a whole.
#65
Originally Posted by toddk911
What causes wheel hop on a hard launch?
And how can you stop it from happening?
#66
Ok. I happened to get on it a bit from a stop light the other day and noticed it. Mostly becuase it has never done it before.
#67
Originally Posted by 95ONE
There's another way to build boost that you can program in to a step / launch rpm. It makes your ignition bounce like a rev limiter. It builds boost. It's very easy. Just sit there. Push on the gas. the Revs bounce off the pre determined rpm, and there you go. Boost. Hard on the Turbo, but lots of honda guys just don't care. Neither do I.
If you can't afford it. then don't do it. This is what I do for a living. Build turbo cars and race for fun. Parts are wholesale, labor is free. I'll break it all day long for fun. SO what. But if I had to pay those ridiculous prices. FOrget it. I wouldn't drag race. I also Autocross and go to Texas World every once and a while. I just went last month to Houston Motorsport Ranch. Great Place. I love my job.
-Dana
#69
I'll look him up! Thanks for the tip.
#70
Yes. DanaT, It's a two stage sort of thing. It is raw fuel dumping into the turbines therefore loading up the boost. And yes, much like that anti lag system. It keeps it boosting. Very simple and easy. But also EXACTLY right on the stress it puts on the turbo. As with most simple and easy things, there are downsides. But, like I said. those that do that sort of thing, either have plenty of cash, or plenty of Back ups! I don't suggest this on any car that need to last.
