No boost - just a woo...woo..noise!!
4th Gear
Took my car out first time this year and after a gentle warm up hit the boost -
but no boost only this woo...wooo......... noise like a fire engine.
Is this a turbo gone bad or could it be a hose come loose?
Car is box standard 220bhp 951.
Steve
Steve
woo woo? Is it a wooo wooo like a fire engine wooo wooo or is it a wooosh wooosh like a fire extinguisher wooosh wooosh? If it is a wooosh wooosh like a fire extinguisher wooosh wooosh instead of a wooo wooo like a fire engine wooo wooo then its reallly probably like a shhhhh shhhhh wich could simply mean a leaking boost line - (check lines under the hood and line going to wastegate) also make certain wastegate is tight.
"Took my car out first time this year" - first time this year? Where are you? Alaska?
Mine made the exact same noise when the turbo had something go through it and trash the compressor side blades.
Pull the J-boot and look. Hope you have a strong stomach, 'cause I have a feeling you're not going to like what you find.
4th Gear
Hi Guys,
The noise only is apparent when boost is expected - other than that engine sounds ok.
Oh by the way I ain't in Alaska - SteveUK (work it out!!)
Steve
Steve
TRB0 GUY
darnit db, you got to it before I could...
"ya don't wancha car like 'woot woot'... ya want 'WOOT! WOOOOOOT!" -Bubb Rubb
"what they doin sleepin at 5am? Dey should be making eggs and bacon..." -Bubb Rubb
... WOOOT! WOOOOOOOOOT!!!!
...I'm guessing a serious boost leak, but do you have a digital cam that could get the noise in a video?
Check the intercooler hose clamps.
If they are loose or off the hose puffing up and letting the air out could vibrate in such a fashion that it would make that noise.
